Single stage paint get darker as it dries??
#1205919
03/29/12 05:39 PM
03/29/12 05:39 PM
Posts: 848 Avondale AZ
Prodart440
Avondale AZ
My son took his daily driver to Maaco back in December to be painted. He had them do the cheap paint, which was a single stage paint. He wrecked the truck in January, and had to put new fenders on it. He had Maaco paint the fenders to match and they are slightly too light (the truck is at Maaco right now). The guy at Maaco said they will darken as the paint cures. Of course I don't believe him, so I had to come on Moparts to get my answer. Will the paint darken as it cures?? or is the guy feeding me a load of crap?? Thanks.
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
Re: Single stage paint get darker as it dries??
[Re: Prodart440]
#1205920
03/29/12 05:46 PM
03/29/12 05:46 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Sounds like a load of crap to me. different paint batches, different conditions when sprayed, and it sounds like they didn't fade the paint well enough into the adjacent "good" panel.
if the paint is close, but only off a little bit, you wouldn't be able to tell if they had faded the paint properly.
**Photobucket sucks**
[Re: 70Cuda383]
#1205921
03/29/12 05:48 PM
03/29/12 05:48 PM
Prodart440
Avondale AZ
How hard is it to blend a single stage paint??
Aaron
[Re: Aero426]
#1205923
03/29/12 06:03 PM
03/29/12 06:03 PM
Prodart440
Avondale AZ
Yeah, he told me that they don't blend single stage paint. The paint is close, just not perfect.
Aaron
[Re: Prodart440]
#1205924
03/29/12 06:32 PM
03/29/12 06:32 PM
Posts: 669 Michigan, USA
ramman5600
Michigan, USA
I think that your last statement after the word perfect should have added = MAACO. Cheap paint job - cheap results
[Re: ramman5600]
#1205925
03/29/12 07:51 PM
03/29/12 07:51 PM
Posts: 4,923 new berlin wisconsin
Mr T2U
single stage paint doesn't darken as it cures. it should be "cured" a short time after it leaves the paint booth. some colors will darken as they dry, especially reds and yellows, and if you clear them too soon they car look lighter than they should. any paint will FADE as it is exposed to sunlight. especially a cheap paint job from maaco. they only apply the absolute minimum amount to get coverage and drive the job out the door. in your case the paint is probably somewhat faded and the person who mixed the paint didn't mix it properly when he made it. on some colors 1/10 of a GRAM of paint can change the color. the painter might not have put enough coats of paint on the car, now the color is light because the sealer under the paint is not fully covered. or he could have used a lighter color sealer than the first job now the color is light. asking for a perfect color match on a cheap paint job from maaco is like asking for the government to stop wasting money.
perception is 90% of reality
[Re: ramman5600]
#1205926
03/30/12 11:07 AM
03/30/12 11:07 AM
Posts: 1,572 Jacksonville Florida
elitecustombody
BINGO!
I take it "you need maaco NOW!" commercials are working well
[Re: elitecustombody]
#1205927
03/30/12 11:38 AM
03/30/12 11:38 AM
Prodart440
Avondale AZ
He just wanted the truck to be one color, that is why he went with the cheap Maaco paint. He would never have had to worry about it if he didn't wreck it less than a month after it was painted. Thanks for all the info. I figured he was giving me a load of crap, just had to ask.
Aaron
