Re: Solid roller lifter opinions
[Re: JackGTX440]
#1205889
03/29/12 05:34 PM
03/29/12 05:34 PM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
Isky Red Zones in my hemi. Sent em back for inspection after 2 years and they needed nothing. That was 2008, still going strong, although it is time for a freshen up.
I just have a regular set of Cranes in my 440. Nothing special, but they've been troublefree after about 3 years worth of abuse.
[Re: an8sec70cuda]
#1205890
03/29/12 05:51 PM
03/29/12 05:51 PM
In a stock block the Morrels ( or is it Morel) are great and the best for the $$--they are pretty low Call Bullet Cams--they are the house brand or better yet call Competition Wedge--he will steer you right- and some other members here sell them just whatever you do skip the Comp 829-16s they are trouble, I had one out of the box the other day and it had one and 1/2 thou taper--it was too big on the fat end and would not even go in the block--
[Re: JackGTX440]
#1205892
03/29/12 08:11 PM
03/29/12 08:11 PM
Posts: 16,928 NC
440Jim
NC
Im in the middle of collecting parts for my single turbo EFI 400 build. I'm looking for opinions on solid roller lifters.
If you have heads with a large offset intake rocker arm (Indy 440-1); then with a low deck I like the offset seat lifters, Comp 892 or 87019
http://www.compcams.com/catalog/COMP2012/pdf/COMP_Catalog_2012_282-291.pdf
Just watch out for this casting bump that gets close to the pushrods.
[Re: Thumperdart]
#1205898
03/30/12 04:24 PM
03/30/12 04:24 PM
Posts: 370 Real North Cal.
66er
Real North Cal.
Isky`s here................solid body and works in un-bushed lifter bores goin on 8+ years, lots of street miles and re-built once after 5 years.
Same here. 5 years rebuilt after 3 because a Crane rocker broke. I also have Isky Tool Room spring that are 5 years old and still test well.
[Re: Cab_Burge]
#1205899
03/30/12 06:50 PM
03/30/12 06:50 PM
Posts: 453 Holly, MI
JackGTX440
Holly, MI
Thanks for the input guys. Are there any others that anyone knows of out there that don't require a bushed lifter bore?
The Crowers have a longer skirt on the oil galley side, they help mask the oil galley at full lift
Hmm, these crowers seem to be a little more in the budget too.
[Re: JackGTX440]
#1205900
03/30/12 09:12 PM
03/30/12 09:12 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
The Crowers and isky are both good pieces, it more comes down to what do you NEED for lifters, based on engine combo and block combination etc. Check your PMs.
RIP Monte Smith
