Re: Fuel Sender
[Re: MD72]
#1205347
03/28/12 09:03 PM
03/28/12 09:03 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
Fuel sender size is generally the same as your fuel pump inlet/outlet size. A 318 should always be 5/16, I would think. Big blocks got the 3/8 ones.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Fuel Sender
[Re: MD72]
#1205348
03/28/12 10:08 PM
03/28/12 10:08 PM
RapidRobert
sending unit steel tubing OD. 5/16" OE on your 318. Slip a 5/16" open end wrench over the line to verify
Re: Fuel Sender
[Re: Secret Chimp]
#1205350
03/29/12 03:37 AM
03/29/12 03:37 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Not always. 350, 361 and 383 TWO barrel cars got the 5/16 line.
Re: Fuel Sender
[Re: Kern Dog]
#1205351
03/29/12 05:59 PM
03/29/12 05:59 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
I believe 383HP cars used 5/16" inch fuel line as well.
I recently bought my 5/16" fuel sending unit from AMS Obsolete's eBay store, in which it's supposed to be an OEM unit. Note that the unit I got has a brass float and not the plastic one as pictured - http://www.ebay.com/itm/150296871944
On a side note, Dwayne Porter is on the record for saying he's ran mid 10 second ETs with 5/16" inch fuel line and a 448CI engine.
