Aluminum Radiator - Which Upper Hose? UPDATE #1205081
03/28/12 12:19 PM
03/28/12 12:19 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Installed a 26" Griffin cross flow radiator. The inlet is about 3" further to the right than stock. I was using a molded upper hose for a '69 Dodge Coronet BB engine, but that won't fit now. Has anyone found a molded upper radiator hose that will fit? The photo is of the Griffin I installed.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Aluminum Radiator - Which Upper Hose? [Re: Junky] #1205082
03/29/12 11:52 AM
03/29/12 11:52 AM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Somebody must have an idea how to remedy this problem besides using a flex hose.
Re: Aluminum Radiator - Which Upper Hose? [Re: Junky] #1205083
03/29/12 03:12 PM
03/29/12 03:12 PM
Australia
Charger VJ RB Offline
Australia
Read this old thread it may get you close to what you need.
https://board.moparts.org/ubbthreads/show...rue#Post6515078
Cheers
RB XE274H Q-850
Re: Aluminum Radiator - Which Upper Hose? [Re: Charger VJ RB] #1205084
03/29/12 03:33 PM
03/29/12 03:33 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Thanks for the help. I'll try those numbers. Or maybe take my old hose and see if I can match it up to one in the NAPA stock room.
Re: Aluminum Radiator - Which Upper Hose? [Re: Junky] #1205085
03/29/12 05:48 PM
03/29/12 05:48 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
My notes say I installed Griffin p/n GRI-1-26222-X. I used Carquest 21343, 82-84 Ford PU, 300 6 cyl w/ac, I had to cut some length off if I recall correctly. It was 10 years ago so I'm not entirely sure on the trimming.
Re: Aluminum Radiator - Which Upper Hose? [Re: dynorad] #1205086
03/30/12 01:22 AM
03/30/12 01:22 AM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Struck out on those numbers. But I did find one that will probably work. I'll need to cut a section out and couple it back together. I'll post later on the results for anyone that runs in to the same situations.
Re: Aluminum Radiator - Which Upper Hose? [Re: Junky] #1205087
03/30/12 02:00 AM
03/30/12 02:00 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
'94 Ford Ranger hose here, I think many people are using it for aluminum rads.
Re: Aluminum Radiator - Which Upper Hose? [Re: Exit1965] #1205088
03/30/12 01:10 PM
03/30/12 01:10 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
NAPA FF242
Re: Aluminum Radiator - Which Upper Hose? UPDATE [Re: Junky] #1205089
03/30/12 09:03 PM
03/30/12 09:03 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Found a NAPA upper hose part #7314. I'll need to cut a section out of it, then back together, with a aluminum tube inside custom made by a friend, with a shrink wrap clamp. I'll post photos when I'm done. Cars/Trucks that it will fit is:
Buick Electra 225 6.6 L 400 CID V8 1966 - 1966
Buick Electra 225 7.0 L 425 CID V8 1965 - 1966
Buick Riviera 7.0 L 425 CID V8 1966 - 1966
Buick Wildcat 6.6 L 400 CID V8 1965 - 1966
Buick Wildcat 7.0 L 425 CID V8 1965 - 1966
Ford Custom 5.8 L 351 CID V8 Cleveland 1974 - 1974
Ford Custom 6.6 L 400 CID V8 1973 - 1974
Ford Custom 500 5.8 L 351 CID V8 Cleveland 1974 - 1974
Ford Custom 500 6.6 L 400 CID V8 1973 - 1974
Ford Galaxie 500 5.8 L 351 CID V8 Cleveland 1974 - 1974
Ford Galaxie 500 6.6 L 400 CID V8 1973 - 1974
Ford LTD 5.8 L 351 CID V8 Cleveland 1974 - 1974
Ford LTD 5.8 L 351 CID V8 Modified 1975 - 1976
Ford LTD 6.6 L 400 CID V8 1973 - 1976
Mercury Grand Marquis 6.6 L 400 CID V8 1975 - 1976
Mercury Marquis 6.6 L 400 CID V8 1973 - 1973
Mercury Marquis 6.6 L 400 CID V8 1975 - 1976
Mercury Monterey 6.6 L 400 CID V8 1973 - 1974
Meteor Montcalm 5.8 L 351 CID V8 1974 - 1974
Meteor Montcalm 6.6 L 400 CID V8 1973 - 1976
Meteor Rideau 500 5.8 L 351 CID V8 1974 - 1976
Meteor Rideau 500 6.6 L 400 CID V8 1973 - 1976
Re: Aluminum Radiator - Which Upper Hose? UPDATE [Re: Junky] #1205090
03/30/12 09:12 PM
03/30/12 09:12 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Would one like this NOT work? It fits fine and there is room to go even more towards the passenger side if needed.
Just a suggestion. What you have planned sounds like a lot of work, I haven't heard of other people needing to go that route.
Re: Aluminum Radiator - Which Upper Hose? UPDATE [Re: Exit1965] #1205091
03/30/12 09:33 PM
03/30/12 09:33 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Naw, it's not a lot of work. Hardest part was finding the right hose and that only consumed maybe 30 minutes looking through NAPA's stuff, and maybe posting on here about it. What hose is that of yours?
Re: Aluminum Radiator - Which Upper Hose? UPDATE [Re: Junky] #1205092
03/30/12 09:53 PM
03/30/12 09:53 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I posted up there ^ it's a 94 ranger hose.
