Re: Ammeter Pegged...Burning Electrical Smell
[Re: 70gtx440dana]
#1205005
03/28/12 04:22 PM
03/28/12 04:22 PM
Posts: 9,312 SoCal
68HemiB
SoCal
What he said. Yes, running all the load through the ammeter was a less than clever design, and the suggested bypass is seen by most as a good idea. HOWEVER, the pegged ammeter at hand is an indication that something else is very wrong. This must be addressed immediately!
Down to just a blue car now.
[Re: 68HemiB]
#1205006
03/28/12 04:37 PM
03/28/12 04:37 PM
RapidRobert
bad voltage reg EDIT pull the triangle VR connector ASAP so it ain't charging. It is far better to deep cycle (run it down then charge it up) the battery a time or 2 till you solve it rather than having the system full fielded like it is now, as said very dangerous
[Re: RapidRobert]
#1205007
03/28/12 10:58 PM
03/28/12 10:58 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
First thing to do is find the problem for overcharging and fix it. Ron
[Re: GO_Fish]
#1205009
03/29/12 07:39 AM
03/29/12 07:39 AM
Posts: 288 Birmingham, England
Mick70RR
Birmingham, England
This happened to me on Monday driving to work. The voltage regulator had burned out. Picked up another reg and was back on the road a few hours later.
1970 Road Runner
505 cid
MCH CNC ported Stealth heads
MP 528 camshaft
4 speed
GV overdrive
11.98 @ 117 on street treads
