Re: another 727 Question
[Re: pacifica]
#1204692
03/27/12 11:00 PM
03/27/12 11:00 PM
Posts: 70 Wyoming, USA
1976Fury
Wyoming, USA
Were you able to test/verify it was a working transmission before you did the shift kit?
No verification that it worked all the bands looked good a fluid was clean
[Re: 1976Fury]
#1204693
03/28/12 01:19 AM
03/28/12 01:19 AM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
Did you air test it when the valvebody was off ?
[Re: 1976Fury]
#1204695
03/28/12 04:16 PM
03/28/12 04:16 PM
Posts: 25,786 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Since the transmission condition was unknown when installed it's possible that the pump is bad. The fluid level is a good indicator of pump function, if the fluid level stays the same when running in Neutral as it was when sitting overnight the pump isn't working.
On the passenger side of the trans there are three "humps" with pipe plugs installed, the center hump is where you measure the line pressure; the shifter has to be in a forward gear when testing.
