Weld bolt or both? #1204596
03/27/12 07:20 PM
03/27/12 07:20 PM
Anywhere the British Secret Se...
Moonraker Offline OP
Bought some subframe connectors for the Duster from mancini the square steel bolt in type. I was just going to weld them in as opposed to bolt them in but I thought I read somewhere that people were doing both. I dont see the point in wasting the time drilling holes and running bolts if I'm welding them in or am I wrong on this?
Re: Weld bolt or both? [Re: Moonraker] #1204597
03/27/12 07:24 PM
03/27/12 07:24 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
We bolted first, then welded.
I was going to remove the bolts then gave it some thought.
I can see where it could be argued that the bolts give some additional
torsional rigidity.
Joe
Re: Weld bolt or both? [Re: Moonraker] #1204598
03/27/12 11:01 PM
03/27/12 11:01 PM
i was thinking that also but wouldnt welding where the screw holes are would serve the same purpose?
Re: Weld bolt or both? [Re: Moonraker] #1204599
03/28/12 12:44 AM
03/28/12 12:44 AM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
Instead of drilling the holes to bolt them on, use the holes to plug weld. I think I like that idea better.
Re: Weld bolt or both? [Re: None2Slow] #1204600
03/28/12 11:47 AM
03/28/12 11:47 AM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
What is the thickness of your connectors? welding two pces of metal with vastly different thicknesses isn't easy and you often get a poor weld. Seeing as how you are probably welding 10ga (.1345) tubing or thicker to 14 (.0747) or 16ga (.0598), I'd go with the bolts myself...probably a reason they sell them as "bolt in".
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Weld bolt or both? [Re: DPelletier] #1204601
03/28/12 02:48 PM
03/28/12 02:48 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Can't imagine when leaving out a strong piece of an assembly will make it better??
Joe
Re: Weld bolt or both? [Re: jlatessa] #1204602
03/28/12 08:16 PM
03/28/12 08:16 PM
IN
ahy Offline
ahy  Offline
IN
The most important part is to weld the perimeter to spread the load on the fairly thin frame rails. It can't hurt to put the bolt in also... that's what I'd do.
