A/C components removed and warm air still coming in! #1204576
03/27/12 06:16 PM
03/27/12 06:16 PM
Pewaukee, WI
Airgrabber Offline OP
Pewaukee, WI
Why would warm air blow out both the defroster vents and the a/c vents after all of the components have been removed. I installed a bypass valve in the heater hose. Is there something else I need to do or check at the heater core? Thanks in advance.
Re: A/C components removed and warm air still coming in! [Re: Airgrabber] #1204577
03/27/12 06:58 PM
03/27/12 06:58 PM
Andrewh Offline
Andrewh  Offline
when you say everything removed, what does that mean?
box is gone? vents are gone?
did you seal up the fresh air ducts?
Re: A/C components removed and warm air still coming in! [Re: Andrewh] #1204578
03/27/12 07:40 PM
03/27/12 07:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what he said ... also explain your bypass valve
Re: A/C components removed and warm air still coming in! [Re: JohnRR] #1204579
03/27/12 11:19 PM
03/27/12 11:19 PM
Pewaukee, WI
Pewaukee, WI
Sorry. All of the underwood components were removed. The bypass is on the heater hose which goes to the water pump. The manifold heater hose goes to the heater core. Could this be backwards?
