727 Trans Lines? #1204286
03/27/12 12:14 AM
03/27/12 12:14 AM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Which line is to the radiator and which line is the return?
Just installed a new aluminum Griffin cross flow radiator.
I'm also running a B&M trans cooler. Is it always best to run the trans lines through the radiator first, then to and through the cooler back to the transmission? Or...?
So, if so, tell me if this is right. Transmission line to radiator, to trans cooler, back to transmission?
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: 727 Trans Lines? [Re: Junky] #1204287
03/27/12 01:18 AM
03/27/12 01:18 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
yes
the line on the front of the transmission is the outlet to the cooler the line in the rear is the return. if using a crossflow radiator i would run the trans outlet to the top of the radiator cooler, the outlet (bottom) of the radiator cooler into the trans cooler then from the outlet of the trans cooler to the back of the trans.
Re: 727 Trans Lines? [Re: jamesc] #1204288
03/27/12 02:09 AM
03/27/12 02:09 AM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Thank you very much! Now I can finish it up tomorrow.
