8 3/4 backlash #1204282
03/27/12 12:06 AM
03/27/12 12:06 AM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Purchased a perfect 742 center from a MOPARTS member that I am going to insatall a posi unit in. Backlash from this untouched unot is a shade over .003" I know the manuals recommend .006-.008 Do I adjust this to specs or retain the original backlash. This unt is untouched since 68.
Re: 8 3/4 backlash [Re: Hemi_Ram] #1204283
03/27/12 02:45 AM
03/27/12 02:45 AM
Is that cleaned up without lube on the teeth or with lube? I firmly belive in the old adage, if it ain't broke, don't fix it
Re: 8 3/4 backlash [Re: Cab_Burge] #1204284
03/27/12 11:50 AM
03/27/12 11:50 AM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
This was a cleaned unit without lube; haven't seen one this tight. I'll set it and check the teeth contact pattern and go from there. Thanks cab
Re: 8 3/4 backlash [Re: Hemi_Ram] #1204285
03/27/12 12:25 PM
03/27/12 12:25 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Must have never been driven , they are never that tight .
If it were me I would install it in a car and drive it BEFORE taking it apart , if you change the backlash it's going to whine and hopefully it can be driven enough to readjust the pattern and quiet it down.
