Are brake shields important? #1204239
03/26/12 10:49 PM
03/26/12 10:49 PM
Mid Michigan
Coronet-R/T-Rag Offline OP
Mid Michigan
I'm doing the "Disc o Tech" disc brake swap on my 67 coronet. I've got everything I need (those spindles and caliper adapters DO NOT grow on tree's by the way). I've got it all, except, the brake shields. I've got them for the 10.75 rotors but not the 11.75. What do you think? Run the 10.75's? Don't run them at all? What do they do? Keep balljoint grease off the rotors?
Thanks.
Re: Are brake shields important? [Re: Coronet-R/T-Rag] #1204240
03/26/12 11:11 PM
03/26/12 11:11 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
i would locate a correct pair,brakes are a particular area that would serve best to be good working order
Re: Are brake shields important? [Re: Coronet-R/T-Rag] #1204241
03/26/12 11:26 PM
03/26/12 11:26 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Some shield is better than no shield, and the proper sized shield is best. There is debris coming up from the roadway - that is the issue. Keeping as much foreign matter off of your brakes as possible should be more than just a minor concern.
Down to just a blue car now.
Re: Are brake shields important? [Re: 68HemiB] #1204242
03/26/12 11:28 PM
03/26/12 11:28 PM
Mid Michigan
Mid Michigan
Am I wrong or do most new cars with disc brakes NOT have shields?
Re: Are brake shields important? [Re: Coronet-R/T-Rag] #1204243
03/26/12 11:29 PM
03/26/12 11:29 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
They all have sheilds
Re: Are brake shields important? [Re: Coronet-R/T-Rag] #1204244
03/26/12 11:32 PM
03/26/12 11:32 PM
Central TX
roe Offline
roe  Offline
Central TX
No you're right (at least I think). New cars don't have them. Personally I think that the spinning rims block all debris from the outside and there's not much chance of something popping up from the inside. I figure if there are millions of new cars running without them, then why can't the classics?
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Are brake shields important? [Re: Coronet-R/T-Rag] #1204245
03/26/12 11:32 PM
03/26/12 11:32 PM
Rancho Cordova, California (Sa...
hemi71x Online content
hemi71x  Online Content
FYI
There is no difference in the diameter of a brake shield for either the 10.80 rotor, or the 11.75 rotor.
They are all the same.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Are brake shields important? [Re: roe] #1204246
03/26/12 11:38 PM
03/26/12 11:38 PM
Dougsmopars Offline
Dougsmopars  Offline
I work on new cars every day. Never seen a factory disc brake car without sheilds. As mentioned above there to keep road trash and stones out of the brakes. Runing disc brakes with no sheilds is asking for problems
Re: Are brake shields important? [Re: Dougsmopars] #1204247
03/27/12 12:00 AM
03/27/12 12:00 AM
Mid Michigan
Mid Michigan
Ahhh. Shields are the same size for big or small rotors. Thanks guys, I'll run them. Gotta love Moparts!
Re: Are brake shields important? [Re: Coronet-R/T-Rag] #1204248
03/27/12 12:13 PM
03/27/12 12:13 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
No I don't think they are that important on a collectible car that presumably doesn't get driven off road. None of my motorcycles have them BTW.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Are brake shields important? [Re: DPelletier] #1204249
03/27/12 12:59 PM
03/27/12 12:59 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
I don't think it's sand or gravel they're supposed to block, but water(-splash).
Re: Are brake shields important? [Re: BigBlockMopar] #1204250
03/27/12 01:11 PM
03/27/12 01:11 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
If you what to run the early shields with late rotors you need to modify them slightly.... The stepped area around the grease seal needs to be removed, it interferes with the larger bearing area of the late style rotor...
Re: Are brake shields important? [Re: 1_WILD_RT] #1204251
03/27/12 07:08 PM
03/27/12 07:08 PM
BDW Offline
BDW  Offline
Found this out the hard way after struggling and wondering why the rotor wouldn't seat, dooh!
Re: Are brake shields important? [Re: Coronet-R/T-Rag] #1204252
03/27/12 07:29 PM
03/27/12 07:29 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
"Are brake shields important?"
IMO, No.
Ask this same question in race or corners forum, and they will likely ask which rock you crawled out from.
As for as debris, I can't say I see much debris collect on the inner surface of a rim, and that surface doesn't have the self cleaning effect of centrifugal force of say a 60 mph spinning rotor. Regarding water splash, seldom is a rotor that hot, and if it is, there is seldom much water around, and if you have ever dropped water on recently hot welded part, the water, instantly vaporizes, carries little heat in the steam bubbles, but not sure what effect water has on friction on a cold rotor, but it still can't remain for long on a spinning rotor.
Factory installed them imo likely because of lawyers, I say dump them both
Re: Are brake shields important? [Re: BigBlockMopar] #1204253
03/27/12 08:32 PM
03/27/12 08:32 PM
DPelletier Offline
DPelletier  Offline
Maybe but I doubt they'd do a very good job of it and like I said earlier; none of my motorcycles have them. I race offroad and routinely cross creeks, mudbogs and even shallow riverbeds and the disk brakes need only moments before returning to full stopping power...heck they even work underwater!
It may seem a bit "apples and oranges" but if exposed disk brake rotors can work in that environment, I can't see automotive ones truly benefitting from the guards. Do F1 cars have them? Baja race vehicles?
Go ahead, put them on (I did) but I seriously doubt you'd ever notice whether they were there or not from behind the wheel.
Re: Are brake shields important? [Re: Coronet-R/T-Rag] #1204254
03/27/12 10:27 PM
03/27/12 10:27 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Thanks.
Since you referred to the Mopar Action brake swap, I'll take it a step further...
According to Mr E-berg, one of the reasons that Ma Mopar used the shields was to keep heat that radiated from the rotors AWAY from the tie rod ends! I omit the shields on my cars though. I havent stressed the brakes enough to get the rotors THAT hot!
Re: Are brake shields important? [Re: DPelletier] #1204255
03/28/12 05:17 AM
03/28/12 05:17 AM
The Netherlands
The Netherlands
... none of my motorcycles have them....
But motorcycles can't experience a sudden brake-difference between the left and right front tires if water just lands on one of the rotors.
There's also no tire 'on the otherside' which can splash water onto the opposite brake-rotor.
On the other hand, these 'dustshields' also have open slots near the center where they mount. It wouldn't surprise me if such a shield is there to aid in brake-rotor cooling somewhat by directing airflow onto/around the rotor better.
Although that leaves to wonder why a shield is only just on 1 side of the rotor and not both.
Re: Are brake shields important? [Re: BigBlockMopar] #1204256
03/28/12 08:43 AM
03/28/12 08:43 AM
Mid Michigan
Mid Michigan
The shields I have are from a 74 coronet. Will I have interference problems?
Re: Are brake shields important? [Re: Coronet-R/T-Rag] #1204257
03/28/12 09:02 AM
03/28/12 09:02 AM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
They are there at least in part to block water. I was having issues with front rotors warping on my '07 Infiniti. They determined that the shields weren't blocking the splash sufficiently. The rotors would get hot, then get wet and warp them. They fitted improved ones and problem solved.
Re: Are brake shields important? [Re: bobs66440] #1204258
03/28/12 09:10 AM
03/28/12 09:10 AM
Lubbock, TX
E
Erics5th Offline
UsedtobeSatellite6
Erics5th  Offline
UsedtobeSatellite6
E
Lubbock, TX
I daily drove my 5th Avenue in Seattle (kinda wet) for a year and a half with no brake shields. Never a problem.
Eric
