4 Link Setting #1204199
03/26/12 10:25 PM
03/26/12 10:25 PM
Alexandria, LA
Blucuda413 Offline OP
Alexandria, LA
Working on a friends car with a Morrison Super Car chassis and I need input on how to set the 4-link up for an initial setting Inputs appreciated. Max
Re: 4 Link Setting [Re: Blucuda413] #1204200
03/26/12 11:51 PM
03/26/12 11:51 PM
Out West
408strokerdart Offline
Out West
I would start with the lower bars level to slightly down, but you really need to plot out the points of the brackets. I have a CAD file of mine and know exactly where mine is with any change. If you don't have those tools accessable to you, plot it on paper, full size on the floor beside the car taking accurate measurements. You will know better on settings after you get some front/rear weights to establish a center of gravity of the car. Also, what is the wheelbase? These items all make a difference. Mine was happy after making one adjustment to the instant center. Good luck with your suspension tuning.
Re: 4 Link Setting [Re: Blucuda413] #1204201
03/27/12 12:01 AM
03/27/12 12:01 AM
MR_P_BODY Offline
MR_P_BODY  Offline
As Brian said... you can lay it all out on the floor
or wall but you have to measure the holes from the
ground and it would be nice if you knew the CG on
it... you might want to try about 35" to 45" with
it up about 6" as a start point
Do it in full size and its easier to see whats happening
Re: 4 Link Setting [Re: MR_P_BODY] #1204202
03/27/12 12:55 AM
03/27/12 12:55 AM
PA
moparacer Online content
moparacer  Online Content
PA
http://www.baselinesuspensions.com/instant-center_general.php
I use this to figure my 4 link IC and AS settings.
A lot of variables go into what a car likes for a IC height and length.
Never 2 that are the same.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
