fuel pressure question... #1204010
03/26/12 06:15 PM
03/26/12 06:15 PM
lewiston, ID
cornucopia Offline OP
lewiston, ID
what would cause fuel pressure to quickly bleed off in a EFI system? I'm working on a port fuel injected rig, the pressure with key on, goes up toward 30, but bleeds right back to zero when pump shuts off.
when I managage to get it started, it maintains 50 or so PSI. when I turn engine off, it bleeds right back to zero...
Re: fuel pressure question... [Re: cornucopia] #1204011
03/26/12 08:14 PM
03/26/12 08:14 PM
Andrewh Offline
Andrewh  Offline
regulator or leaky injector.
only 2 options.
Re: fuel pressure question... [Re: Andrewh] #1204012
03/26/12 09:00 PM
03/26/12 09:00 PM
Andrewh Offline
Andrewh  Offline
forgot.
if you pinch off the fuel hose after it hits 50 psi and it drops (with the car off) it is a leaky injector.
if it is the reg don't worry about it. happens, just makes it hard to start.
Re: fuel pressure question... [Re: Andrewh] #1204013
03/27/12 10:18 AM
03/27/12 10:18 AM
lewiston, ID
lewiston, ID
does the pump have a one-way check valve of some sort?
Re: fuel pressure question... [Re: cornucopia] #1204014
03/27/12 11:39 AM
03/27/12 11:39 AM
Andrewh Offline
Andrewh  Offline
I don't know of one that does. mostly it is in the regulator.
Re: fuel pressure question... [Re: Andrewh] #1204015
03/27/12 05:07 PM
03/27/12 05:07 PM
lewiston, ID
lewiston, ID
thanks for the info!
Re: fuel pressure question... [Re: cornucopia] #1204016
03/27/12 05:38 PM
03/27/12 05:38 PM
lewiston, ID
lewiston, ID
UPDATE: I clamped the return line closed, and it STILL bleeds off pressure. must be an injector...
Re: fuel pressure question... [Re: cornucopia] #1204017
03/27/12 06:09 PM
03/27/12 06:09 PM
Andrewh Offline
Andrewh  Offline
well not necesarrily.
depends on how it is setup.
like mine goes pump, regulator with return line to the injectors.
clamping off the return wouldn't prove anything.
dodge trucks do a returnless system, so clamping it off where it feeds the rail would show it is injectors.
I think ford does it where it pumps to the rail then returns off the rail.
in that case you would have to clamp both lines. the return first then the fill line.
Re: fuel pressure question... [Re: Andrewh] #1204018
03/27/12 09:15 PM
03/27/12 09:15 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
What exacty are you working on? Knowing what it is may help with the diagnoisis.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: fuel pressure question... [Re: 71yelladustr] #1204019
03/27/12 09:57 PM
03/27/12 09:57 PM
lewiston, ID
lewiston, ID
a ford...1987,4.9 L(300 six)
Re: fuel pressure question... [Re: cornucopia] #1204020
03/27/12 10:38 PM
03/27/12 10:38 PM
Missouri U.S.A.
Missouri U.S.A.
Why dont you pop the rail and injectors out of the intake so you can see what they are doing? With them raised out of the intake, cycle the key, watching if they leak down. Does the engine act like its flooded when trying to restart? That would also be an indication of leaky injectors.
10.02@134
Re: fuel pressure question... [Re: 71yelladustr] #1204021
03/27/12 10:56 PM
03/27/12 10:56 PM
lewiston, ID
lewiston, ID
yeah, it is real hard to start...pulling the rail is a real pain on this motor. but it needs to be done. I will see what I find. thanks guys!
