which carb #1203913
03/26/12 04:02 PM
03/26/12 04:02 PM
United states wisconsin
bigblockbryan Offline OP
okay im thinking about buying a a carb for my fury its got a 750 dp that works great. But is not mine so how are those holley street avenger carbs or should i splurge and buy a demon my one buddy says a demon is just a fancy double pumper. The motor that it will be on is a 440 with roughly 10.1 comp 452 heads dual plane performer intake comp cam 484 mopar perfomance igntion with stock springs that should be changed
Re: which carb [Re: bigblockbryan] #1203914
03/26/12 09:01 PM
03/26/12 09:01 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Check all your options...Take a look at the Quick-Fuel carbs...They're some nice units at a reasonable price...Lots of goodies on the street models only the high end or racing carbs have in the other brands..I've used them on the last two builds and am very happy with the tuneability/performance...
Re: which carb [Re: screamindriver] #1203915
03/26/12 09:03 PM
03/26/12 09:03 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
Someone mentioned the Quick Fuel Slayer 750 yesterday. It looks like a nice carb for $299.
Scott
1969 Super Bee, 383/4 speed
Re: which carb [Re: StukaJU87] #1203916
03/26/12 09:51 PM
03/26/12 09:51 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Just ordered a 750 Slayer Quick Fuel carb. Going to install this weekend. Got an Eddy on it now and they suck with big cams. Idle circut is all vac. Big cams and vac don't go together. Does look like a nice carb for the price. A lot of features you only find on race carbs from the big names
Re: which carb [Re: bigblockbryan] #1203917
03/26/12 10:15 PM
03/26/12 10:15 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
why mess with it. Get another 750 DP or HP carb.
Coming soon!!!!
Re: which carb [Re: Mr.Yuck] #1203918
03/26/12 10:18 PM
03/26/12 10:18 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I have a 770 Street Avenger, expect to play with it as they're pretty lean out of the box.
Re: which carb [Re: GTX MATT] #1203919
03/27/12 11:58 AM
03/27/12 11:58 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
If your DP runs good buy your friend a new one or take notes on all the list numbers, jets, PV's, squirters, acc. pump cams, idle screw settings, etc so you can get close right away.
Re: which carb [Re: radar] #1203920
03/28/12 12:14 PM
03/28/12 12:14 PM
yea his a litele rich on my combo his is jetted for 569 horse he said
