Hughes converters? #1203789
03/26/12 09:42 AM
03/26/12 09:42 AM
Spring Mount, PA
MOPAULY Offline OP
MOPAULY  Offline OP
Spring Mount, PA
The prices are attractive, anyone run on and what are opinions?
Re: Hughes converters? [Re: MOPAULY] #1203790
03/26/12 12:32 PM
03/26/12 12:32 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
I ran the 2500 Street Master with a stock 383 and 3.23 rear gears. Engine would flash to 2,500 RPM off the line. Acted like a stock converter. Nice converter. Excellent service from Hughes Performance.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Hughes converters? [Re: Junky] #1203791
03/26/12 01:08 PM
03/26/12 01:08 PM
Iowa, US
oldsklharo Offline
oldsklharo  Offline
Iowa, US
Sorry I don't have any good advice for ya but I am looking for the same answers as you so I'll be watching and learning
Re: Hughes converters? [Re: MOPAULY] #1203792
03/26/12 01:08 PM
03/26/12 01:08 PM
Missouri
bb74swngr Offline
mopar addict
bb74swngr  Offline
mopar addict
Missouri
Same good experience as Junky. Mine is behind a very mild 440 and flashes 27-2800. My tranny is still full auto and it shifts like a stock converter.
BigBlock 74 Swinger
Re: Hughes converters? [Re: bb74swngr] #1203793
03/26/12 01:33 PM
03/26/12 01:33 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I've had a couple of Hughes converters, mostly shelf stuff. All have worked well.
This car had a 10" 3500 converter. Ran pretty good, 1.43 60's, and 6.94 et.
http://imageshack.us/clip/my-videos/13/irwindalevids003.mp4/
Re: Hughes converters? [Re: RobX4406] #1203794
03/26/12 04:15 PM
03/26/12 04:15 PM
Spring Mount, PA
MOPAULY Offline OP
MOPAULY  Offline OP
Spring Mount, PA
Thanks guys - they are decently priced and I'm not trusting my old TCI.
Re: Hughes converters? [Re: MOPAULY] #1203795
03/26/12 06:59 PM
03/26/12 06:59 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
I have the Hughes Street Master in my station wagon. Drives like a normal converter under light acceleration. Stomp on it and
Scott
1969 Super Bee, 383/4 speed
Re: Hughes converters? [Re: StukaJU87] #1203796
03/26/12 07:11 PM
03/26/12 07:11 PM
USA
CrAlt Offline
CrAlt  Offline
USA
I had a off the shelf 904 'Street Master' one and it worked fine for years. Outlived 2 904's behind 2 different engines.
At one point I did crack the snout (and broke the pump ears..prob because I was running a Cheeta manual RVB on the street ) and a local converter shop was able to fix it no problem.
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
Re: Hughes converters? [Re: Junky] #1203797
03/26/12 11:21 PM
03/26/12 11:21 PM
Missouri
MY340 Offline
MY340  Offline
Missouri
I got the same converter in my Duster. I like it too.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: Hughes converters? [Re: MY340] #1203798
03/27/12 12:20 AM
03/27/12 12:20 AM
Los Angeles, CA
Mobarge Offline
Mobarge  Offline
Los Angeles, CA
Love mine. Flashes where it should (~3,000 RPM)
'71 SSP - SOLD!
Re: Hughes converters? [Re: Mobarge] #1203799
03/27/12 09:11 AM
03/27/12 09:11 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I have one they call the 10" 3000 stall. Flashes at 2800, could be my combo but I expected higher. Other than that, it seems to do the job, having nothing to compare it to.
I read someone else on here (in the race forum) mentioned they picked up 7 tenths by swapping out their Hughes converter for another, that it would slow any car down, but I don't know what the problem was with it.
Re: Hughes converters? [Re: Exit1965] #1203800
03/27/12 01:26 PM
03/27/12 01:26 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Yeah, I saw that post too. But then you have other people, like a friend of mine that runs a '70 Chevelle in the low 9's, that won't run anything else but a Hughes. And I've seen other posts that claim Hughes are good converters. So...
