383 water pump housing #1203660
03/26/12 01:37 AM
03/26/12 01:37 AM
USA
JoesMopar Offline OP
USA
Do you use a sealer on the mounting gaskets for the water pump housing or just the gaskets by themselves?
Re: 383 water pump housing [Re: JoesMopar] #1203661
03/26/12 02:33 AM
03/26/12 02:33 AM
Gladstone, Michigan
UP FM3challenger Offline
Gladstone, Michigan
I've had good luck with just the gasket along with a coat of high-tack sealer on both sides. Only place I would use sealer/silicone is at the four corners of the intake gasket/valley pan.
