Re: AAR Quick Ratio Steering Gear Box
[Re: AAR#2]
#1203362
03/25/12 08:56 PM
03/25/12 08:56 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
I believe the different internal parts to the T/A box are not serviced items. But if you go to http://www.hamtramck-historical.com . Barry lists a TSB on quick ratio that tells technicians the differences. I've never rebuilt one. I need and want to. I'd think it would be easier than a automatic trans. Harder than a carburetor. Harder than assembling a motor. My WAG and is it's about as hard as rebuilding a manual 4spd transmission. But that is a total guess and I've never rebuilt a manual trans.
[Re: 1_WILD_RT]
#1203366
03/25/12 10:30 PM
03/25/12 10:30 PM
autoxcuda
So Cal
Well I've rebuilt all of the above & the only one I send out to a pro these days is the steering box.... Technically it's very basic but for some reason I've never had any luck keeping the fluid inside.... I bought the special tools, I'd just rather send it to Firm Feel....And BTW the box ratio is the same as other boxes, it just has the internal limiter stops altered for the longer pitman arm....
What do the special tools comprise of?
So you can get them to work fine, but the just leak on you? Of course that's not acceptable, but something to keep in mind.
Is there a certain seal or area you had a problem with?
[Re: AAR#2]
#1203367
03/25/12 10:38 PM
03/25/12 10:38 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Special tools consist of spanner wrenches for the two nuts... After doing one with adjustable spanners & not having any luck getting it to not leak.. They seem to like to leak from the cover on top of the sector...
[Re: 1_WILD_RT]
#1203368
03/25/12 10:45 PM
03/25/12 10:45 PM
autoxcuda
So Cal
You bought the right spanners and you had the same leaking out of the top as you did with the adjustable spanners?
[Re: AAR#2]
#1203371
03/26/12 01:12 AM
03/26/12 01:12 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
No, not the valve body, the domed cover that acts as the top support for the sector shaft.. I've had no problems with the valve body, the lower sector shaft seal, or the worm seal... The thing that looks like it should be trouble free has leaked on three separate steering boxes... If I had access to a test stand so I could pressurize the gear before installation I'd play around with one again but the trouble to bolt one into a car only to have it leak is more work than I care to go through... I'll go with sending it to Dick @ Firm Feel.. FWIW back in the eighties the seal kit was available through Napa for around $12...
[Re: 1_WILD_RT]
#1203373
03/26/12 02:46 AM
03/26/12 02:46 AM
autoxcuda
So Cal
Do they sell a kit with new bearings?
