318 upgrades #120320
09/13/08 08:43 PM
09/13/08 08:43 PM
Windsor, Ontario
P
project74 Offline OP
P
Windsor, Ontario
Hi fellas. Time to upgrade a few things on the boat, ('70 Fury), and I just have a couple of quick ?'s. (Please hold the "build a 360" thing. With gas almost $6 a gallon here I'd like to be able to drive it The combo so far:
-Bone stock 318. Comp ratio about 8.8:1
-Edelbrock LD4B intake
-Fully rebuilt '88 302 casting heads,(unported), built to stock specs. Got a great deal on these and couldn't turn them down. Figure compression could boost to 9:1 and they gotta be better than the stock 675's on there now.
-Carter AVS from a '70 383 A/T. Flow about 635 cfm.
Now...how much lift can a new, stock '88 valve spring take? Keep it under .450 and I'll be ok? Also looking for cam recommendations. Thinking maybe a Comp 260H. Stock 904 trans and a 2.76 rear gear. Looking just to give it a bit more punch. The big block plans will have to hold till I win the lottery
Thanks and awaiting your wisdom...
1970 Fury III, 318, 4 dr hardtop, aka "The Fridge"
Re: 318 upgrades [Re: project74] #120321
09/13/08 09:34 PM
09/13/08 09:34 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
keep the cam under 220@.050 you will have to check the max valve lift, use a 4 hole spacer under the carb to help the low end
Re: 318 upgrades [Re: ademon] #120322
09/13/08 10:09 PM
09/13/08 10:09 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
Those gears are killing any punch you have. I would look for different rear 3rd member. I am guessing its an 8 3/4
Re: 318 upgrades [Re: Posest] #120323
09/13/08 11:21 PM
09/13/08 11:21 PM
Central NC
gch Offline
gch  Offline
Central NC
In that application I would go with the xe256 or similar lunati voodoo grind.You need short duration with those gears and the weight of the car.The lift associated with cams of this size should not be a problem but I am a small block dummy so check to be sure.
Re: 318 upgrades [Re: gch] #120324
09/14/08 12:04 AM
09/14/08 12:04 AM
When you do switch heads you might measure your deck height so you can calculate your actual CR for reference but you are in the 7's now.
Re: 318 upgrades [Re: RapidRobert] #120325
09/14/08 12:18 AM
09/14/08 12:18 AM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
A heavy C with the combo recommended should run at least 3.23's for gears with a 28" tall tire (23570R15).
Run 2-1/4" dual exhaust Dynomax Super Turbo muffs for good torque response and fuel economy.If not going with headers,use early Dakota Magnum logs or 360 logs.
Recurve the distributor for advance to come in early to move the tank.
You can get amazing fuel economy and performance by using a tuned Thermoquad carb.
When you switch your heads,roller lifters and rockers can help MPG.So can electric cooling fans.The less parasitic drag,the better MPG.
Also it is best to match the convertor to the suggested XE256 cam choice by going one step up in stall speed.
When set up properly with the right engine parts combination,24 MPG highway can be achieved.
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: 318 upgrades [Re: 68Cbarge] #120326
09/14/08 01:53 AM
09/14/08 01:53 AM
302s had HORRIBLE valve springs, a stock cammed 80s 318 floated at 4500-5000 RPM. Definitely invest in some beefed up springs.
Rocker arms too, those are pretty weak. Ask me how I know that.
Re: 318 upgrades #120327
09/14/08 02:03 AM
09/14/08 02:03 AM
Windsor, Ontario
P
P
Windsor, Ontario
I'll actually be using the rockers and shafts from the '70 heads since they're in such good shape. As for gears, plans are to eventually go with 3.23's Rear is actually an 8.25 and yes it's original, believe it or not. I can't see compression being in the 7's, stock compression listed for a '70 teen is 8.8:1 in every piece of literature I've read. Might be down a bit but that much? Cylinder pressure is really good across the board.
Re: 318 upgrades [Re: project74] #120328
09/14/08 02:10 AM
09/14/08 02:10 AM
I was thinking advertised was 8.2 or 8.4. At 8.8 I would agree.
Re: 318 upgrades [Re: RapidRobert] #120329
09/14/08 01:50 PM
09/14/08 01:50 PM
I have the same setup as you have except the 302 heads. in a 72 sebring with 3.23 gears.
I have this cam. Very nice.
http://www.lunaticams.com/Product.aspx?id=2340&gid=297
Re: 318 upgrades #120330
09/14/08 06:12 PM
09/14/08 06:12 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I know you stated to hold the 360 comments, but...
In something as heavy as that Fury a motor with a little more displacement and power might actually yield the same mileage, if not better due to the fact it doesn't need to work as hard.
Re: 318 upgrades [Re: MarkZ] #120331
09/14/08 08:45 PM
09/14/08 08:45 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
add a small displacement supercharger or turbo charger and add efi. you'll be surprised at the mileage and power will pick up.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: 318 upgrades [Re: Jerry] #120332
09/15/08 03:19 PM
09/15/08 03:19 PM
scratchnfotraction Offline
I am with 318 sebring
a voodoo cam and comp 901-16 springs
I am running a roller 60710
258/264
207/213@.050
108/112 icl/lsa
.485/.485 lift
works very good in a heavy 1/2 ton truck with 3.23s,gets about 19 mpgs keeping it down under 2500 rpms
gots lots of mid range,very nice for a 318 IMO
Re: 318 upgrades [Re: scratchnfotraction] #120333
09/15/08 09:20 PM
09/15/08 09:20 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
a big car like that I'd use a voodoo 60400 or com XE250, with comp 901 valve springs and stock locks/retainers.
2017 Grand Cherokee Overland
Re: 318 upgrades [Re: patrick] #120334
09/16/08 01:50 AM
09/16/08 01:50 AM
Windsor, Ontario
P
P
Windsor, Ontario
Yeah, I'm starting to look more at the torque heavy cams. This thing will almost never see 5000 rpm so great bottom and good mid is what I'm after.
I can dig the whole 360 argument, hell I've even got one in the garage. Couple of the things that made up my mind though was the cost of a full rebuild for the 360 (which it needs) and that by the time I get the cam I'll be about $500 bucks in for the entire 4 brl/heads/cam thing which is what I can afford for the foreseeable future. As for turbos, superchargers and things...for that coin I'd just go BB
Re: 318 upgrades [Re: project74] #120335
09/16/08 02:08 AM
09/16/08 02:08 AM
dogdays Offline
dogdays  Offline
Don't go over 208 intake duration at 50 lift, the VooDoo "00" cam referenced above is the biggest cam you could use in that combo and still get decent mileage and lower end power. Keep in mind that the stock 318 cam intake duration at 50 lift is something like 178 degrees. The abovementioned cam is 30 degrees bigger at 50 lift. The Edelbrock Performer is something like 204 at 50, the Comp high energy 252 is something like 205. I'd also look at the Comp XE 250. Check out the dyno charts compared to the next two sizes of the Comp. Admittedly they are in a chevy engine but the XE250 makes a pretty strong statement.
R.
