Re: A-Body BB or Hemi Z-Bar Question [Re: 70HemiGTX] #1203126
03/29/12 11:25 AM
03/29/12 11:25 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have a Lakewood bell in my Dart and it works fine with a factory z-bar and off-set bracket. The alignment is off by a little, but not much. I can live with it where it is. Clutch works fine also. I can try to get some pics of it this evening and post them if anyone wants to see some.
Do you know what year the Lakewood was made and do you have the part number? I say that because I tried to use one for my 383 Dart in the late 70's and there was no way. That is when I found the Ansen was specifically made for a big block A-Body, and even works in the early A cars as well.
JB Rhinehart, Realist
A-Body's RULE!
Re: A-Body BB or Hemi Z-Bar Question [Re: Rhinodart] #1203127
03/29/12 01:09 PM
03/29/12 01:09 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I'm not sure of the year of the housing. I know I bought it used, repainted it and only remember the SFI sticker on it that I taped over. I don't recall seeing a part# stamped any where on the thing. Doesn't mean there isn't one there. Just didn't pay attention or notice it. I can look though. Any where in particular that I should look for a p/n?
Re: A-Body BB or Hemi Z-Bar Question [Re: 70HemiGTX] #1203128
03/29/12 01:43 PM
03/29/12 01:43 PM
USA
SSAAHemiFan Offline OP
USA
If you can post a pic or 2 when you can that would be great.
A buddy dropped off another Lakewood shield today on his way to work.
It was on a 65 B-body that was raced forever.
Both shields are 2 piece. No P/N found on either but the "early" one is noticebly heavier in weight.
Re: A-Body BB or Hemi Z-Bar Question [Re: SSAAHemiFan] #1203129
03/29/12 02:32 PM
03/29/12 02:32 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Mine is a one-piece. I had a two-piece, but sold that many years ago. Should have kept it.
Re: A-Body BB or Hemi Z-Bar Question [Re: 70HemiGTX] #1203130
03/29/12 06:36 PM
03/29/12 06:36 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Mine Lakewood was a one piece with the big plate and 17 freakin' bolts that held it together! The Ansen design is similar and has dual bolt patterns for small or big block.
A-Body's RULE!
Re: A-Body BB or Hemi Z-Bar Question [Re: Rhinodart] #1203131
03/29/12 07:05 PM
03/29/12 07:05 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I took some pics, but I don't know what we can see. Pretty crowded in there.
Re: A-Body BB or Hemi Z-Bar Question [Re: 70HemiGTX] #1203132
03/30/12 12:07 AM
03/30/12 12:07 AM
USA
USA
Thanks for the pic 70HemiGTX
Measured both shields tonight and the mounting bracket for the Z-bar is in the same location.
The bolt holes were worn on the second shield (race car) - so the bolts were sloppy - the location of the holes was the same on both.
I edited my above post where I said the bolts were different sizes. My error.
I will try to post a pic with the dimensions tomorrow.
Re: A-Body BB or Hemi Z-Bar Question [Re: 70HemiGTX] #1203133
03/30/12 01:20 AM
03/30/12 01:20 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
That is definitely different than the one I had, the bracket welded to the housing looks correct for an A-Body!
A-Body's RULE!
Re: A-Body BB or Hemi Z-Bar Question [Re: Rhinodart] #1203134
03/30/12 06:14 AM
03/30/12 06:14 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I really only remember seeing Lakewoods with those bracket welded on to the. I never saw any with out the bracket. I figured they are all the same. I'll have to keep my eyes open at the swap meets this spring.
Re: A-Body BB or Hemi Z-Bar Question [Re: 70HemiGTX] #1203135
03/30/12 10:21 AM
03/30/12 10:21 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
The B-Body and E-Body only uses one hole for the ballstud while the A-Body and C-Body utilizes 2 holes for the special bracket required. I have seen plenty of Lakewoods with just the single hole that the ballstud screws directly into.
A-Body's RULE!
Re: A-Body BB or Hemi Z-Bar Question [Re: Rhinodart] #1203136
03/30/12 10:33 AM
03/30/12 10:33 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I have an old 1 piece blowsheild at home ... no idea who made it ... , I'll have to look at it to see how it compares to the Lakewood I have.
Re: A-Body BB or Hemi Z-Bar Question [Re: JohnRR] #1203137
03/30/12 02:57 PM
03/30/12 02:57 PM
Oh Canada
E
EV2CUDA Offline
EV2CUDA  Offline
E
Oh Canada
I removed all the z bar parts and installed a hydraulic unit that bolts to the trans. Header issues are gone! My 2 cents!
71 Barracuda 383 4spd (500ci)
69 camaro 598, NOS
69 barracuda bbc procharger
77 t/a 6.0 turbo project
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
78 Warlock 5.7 hemi project
Re: A-Body BB or Hemi Z-Bar Question [Re: EV2CUDA] #1203138
03/30/12 05:47 PM
03/30/12 05:47 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
Boy I wrestled with the Z bar and headers on my HEMI dart for a month, finally went the hyd route. I'm not in love with it, but it works easy enough, would of loved to keep the Z bar and all.
Re: A-Body BB or Hemi Z-Bar Question [Re: DANA60] #1203139
03/31/12 04:39 PM
03/31/12 04:39 PM
USA
USA
Here is a pic of the Z-Bar bracket location on a Lakewood shield if anyone is interested.
I am going to cut and relocate it as soon as I am off crutches.
Thanks to everyone who contributed info and pics.
In case measurements are hard to read on your screen:
Top to bottom
1 5/8
1/2
1 1/4
2 1/2
Re: A-Body BB or Hemi Z-Bar Question [Re: SSAAHemiFan] #1203140
03/31/12 11:37 PM
03/31/12 11:37 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Top to bottom
1 5/8
1/2
1 1/4
2 1/2
Which way are you moving it?
Re: A-Body BB or Hemi Z-Bar Question [Re: 70HemiGTX] #1203141
04/01/12 12:06 AM
04/01/12 12:06 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Do you want the measurements off of a factory bellhousing or the Ansen I have?
A-Body's RULE!
Re: A-Body BB or Hemi Z-Bar Question [Re: 70HemiGTX] #1203142
04/01/12 01:23 AM
04/01/12 01:23 AM
USA
USA
[quote
The bellhousing side pivot ball has to end up 1" lower and approx 1/2 forward from where it is now -
I am going to split the difference between both components ( move the bellhousing bracket forward the 1/2" and just lower the ball location on the bolted on bracket). I had to push the firewall in to clear the bell bracket so this will fix both problems.
Rhino - Thank you for the offer, it's totally up to you. I am going to just cut and change what I have - Chances of finding a Ansen are slim.
I put the original Lakewood location on there just for "general knowlege". It may help others in the future.
I will post pics of the mods when I finish them and more importantly let you know if they worked.
Thanks ALL
Re: A-Body BB or Hemi Z-Bar Question [Re: SSAAHemiFan] #1203143
04/01/12 09:20 AM
04/01/12 09:20 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
[quote
Thanks ALL
If you had to push the firewall in to clear that bracket, are you sure you have the engine sitting at the correct location? I have plenty of room to the fire wall. Also, is the engine sitting level from side to side? Having to move the bracket down 1" seems like an awful lot to be off. Just asking.
