Re: A-Body BB or Hemi Z-Bar Question
[Re: Rhinodart]
#1203127
03/29/12 01:09 PM
03/29/12 01:09 PM
Posts: 2,361 PA
70HemiGTX
PA
I have a Lakewood bell in my Dart and it works fine with a factory z-bar and off-set bracket. The alignment is off by a little, but not much. I can live with it where it is. Clutch works fine also. I can try to get some pics of it this evening and post them if anyone wants to see some.
Do you know what year the Lakewood was made and do you have the part number? I say that because I tried to use one for my 383 Dart in the late 70's and there was no way. That is when I found the Ansen was specifically made for a big block A-Body, and even works in the early A cars as well.
I'm not sure of the year of the housing. I know I bought it used, repainted it and only remember the SFI sticker on it that I taped over. I don't recall seeing a part# stamped any where on the thing. Doesn't mean there isn't one there. Just didn't pay attention or notice it. I can look though. Any where in particular that I should look for a p/n?
[Re: 70HemiGTX]
#1203128
03/29/12 01:43 PM
03/29/12 01:43 PM
Posts: 2,431 USA
SSAAHemiFan
USA
If you can post a pic or 2 when you can that would be great. A buddy dropped off another Lakewood shield today on his way to work. It was on a 65 B-body that was raced forever. Both shields are 2 piece. No P/N found on either but the "early" one is noticebly heavier in weight.
[Re: 70HemiGTX]
#1203130
03/29/12 06:36 PM
03/29/12 06:36 PM
Posts: 43,547 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Mine Lakewood was a one piece with the big plate and 17 freakin' bolts that held it together! The Ansen design is similar and has dual bolt patterns for small or big block.
JB Rhinehart, Realist
A-Body's RULE!
[Re: SSAAHemiFan]
#1203140
03/31/12 11:37 PM
03/31/12 11:37 PM
Posts: 2,361 PA
70HemiGTX
PA
Here is a pic of the Z-Bar bracket location on a Lakewood shield if anyone is interested.
I am going to cut and relocate it as soon as I am off crutches.
Thanks to everyone who contributed info and pics.
In case measurements are hard to read on your screen: Top to bottom 1 5/8 1/2 1 1/4 2 1/2
Which way are you moving it?
[Re: SSAAHemiFan]
#1203143
04/01/12 09:20 AM
04/01/12 09:20 AM
Posts: 2,361 PA
70HemiGTX
PA
[quote
The bellhousing side pivot ball has to end up 1" lower and approx 1/2 forward from where it is now -
I am going to split the difference between both components ( move the bellhousing bracket forward the 1/2" and just lower the ball location on the bolted on bracket). I had to push the firewall in to clear the bell bracket so this will fix both problems.
Rhino - Thank you for the offer, it's totally up to you. I am going to just cut and change what I have - Chances of finding a Ansen are slim.
I put the original Lakewood location on there just for "general knowlege". It may help others in the future.
I will post pics of the mods when I finish them and more importantly let you know if they worked.
Thanks ALL
If you had to push the firewall in to clear that bracket, are you sure you have the engine sitting at the correct location? I have plenty of room to the fire wall. Also, is the engine sitting level from side to side? Having to move the bracket down 1" seems like an awful lot to be off. Just asking.
