383 2 barrel air cleaner #1203101
03/25/12 12:24 PM
03/25/12 12:24 PM
CENTRAL MINN
1965_PLYMOUTH Offline OP
CENTRAL MINN
I was wondering if the 1968 and 1969 2 barrel 383 Chargers used the same air cleaner housing? and what else would possibly interchange
Re: 383 2 barrel air cleaner [Re: 1965_PLYMOUTH] #1203102
03/26/12 12:15 AM
03/26/12 12:15 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
383 2 bbl equipped cars from the same year as the car you have should have the same air cleaner .
Re: 383 2 barrel air cleaner [Re: 1965_PLYMOUTH] #1203103
03/26/12 01:15 PM
03/26/12 01:15 PM
Indiana
GrnMagic77 Offline
Peter Parker
GrnMagic77  Offline
Peter Parker
Indiana
Can't say about the Chargers...but for my '68 Plymouth Fury with a 383 2bbl Holley,I swapped off the original air cleaner housing for one from a '69 383 2bbl Holley Fury...basically about the same with the exception of being able to use a pie tin on the '69 since the top is a bit different,baseplates were the same.
1978 Round Up-1977 Warlock-1977 Powerwagon Adven.- 1976 Blue "Macho"-1974 Charger-1968 Fury III -1966 Newport *
Re: 383 2 barrel air cleaner [Re: 1965_PLYMOUTH] #1203104
03/27/12 05:42 PM
03/27/12 05:42 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Nicksgarage.com has a good aircleaner section with lots of info/pics.
Re: 383 2 barrel air cleaner [Re: Fury Fan] #1203105
03/27/12 11:17 PM
03/27/12 11:17 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Thanks for the plug but my page covers hipo applications. I don't know much about the lopo stuff.
