Re: Replacing dimmer switch.
[Re: MonGoo$e]
#1202768
03/24/12 11:01 PM
03/24/12 11:01 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
Just remove the plastic cover around the upper column.It shoud be like 3 or 4 I believe Torx screws.The switch is right there.It unscrews also.Then unplug it.Just make sure you install it properly.They kind of have to slip in just right.Really an easy job.Its called a multi function switch by the way.Rocky
Chrysler Firepower
[Re: MonGoo$e]
#1202771
04/04/12 08:09 AM
04/04/12 08:09 AM
Posts: 905 SD
zrxkawboy
SD
My next guess would be a bad connection somewhere.
It's Swifty! Swifty, you toad sucker!
