Re: roller pilot bearing too loose in end of crank-Help
[Re: chargers777]
#1202666
03/24/12 07:45 PM
03/24/12 07:45 PM
Posts: 25,756 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Depending on how loose it is you might try "tattooing" it; go around the outer periphery with a bunch of center punch dimples to expand the diameter and then install it with red Loctite.
[Re: chargers777]
#1202675
03/25/12 09:26 AM
03/25/12 09:26 AM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Like others have posted above, just dimple it with a sharp center punch and install it with red Locktite I would use the formula called "stud and bearing mount" I believe it's #271 If that fails then try the shim stock.I think the crank and the metal that holds the bushing are two different types of material and tacking it in there might not be the ideal repair Gus These are the ones you tried allready?
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
