best way to remove dried polish compound from louvers?? #1202634
03/24/12 05:42 PM
03/24/12 05:42 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
I have a 69 GTX. There is dried polishing compound in the louvers just forwrd of the windshield. It looks like crap and I want to remove it. I tried a dremel tool with a soft pad but that is dulling the paint. Would 2000 grit sand paper damage the paint if used very soft? Any suggestions??
Re: best way to remove dried polish compound from louvers?? [Re: frank] #1202635
03/24/12 06:38 PM
03/24/12 06:38 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I would start with a Q tip & rubbing alcohol... If it's truly compound it should break down chemically without getting physically aggressive.....
Re: best way to remove dried polish compound from louvers?? [Re: 1_WILD_RT] #1202636
03/24/12 07:05 PM
03/24/12 07:05 PM
K
Kiddart Offline
Kiddart  Offline
K
try muprhys oil soap and warm water. it may not be very aggresive but will not hurt teh finish on the louvers. I know it cuts wax like crazy. dont ask how I know its a long stupid story.
Thank you
Kiddart
Re: best way to remove dried polish compound from louvers?? [Re: frank] #1202637
03/24/12 11:50 PM
03/24/12 11:50 PM
Water, elbow grease and a tooth brush
Re: best way to remove dried polish compound from louvers?? [Re: Cab_Burge] #1202638
03/25/12 03:36 AM
03/25/12 03:36 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Wax and Degreaser, same stuff that you use as a prepwipe for painting.
I am truckless..
Re: best way to remove dried polish compound from louvers?? [Re: 340SHORTY] #1202639
03/25/12 08:23 PM
03/25/12 08:23 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
set a wet sponge (or sponge with wax remover) on top for 20 minutes or so first. Hopefully this will soften the crusted stuff before you start. I've got paint flaking in my louvers where they were not prepped correctly before repaint.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: best way to remove dried polish compound from louvers?? [Re: GO_Fish] #1202640
03/26/12 01:01 AM
03/26/12 01:01 AM
Bismarck, ND USA
cageman Offline
cageman  Offline
Bismarck, ND USA
wax and grease remover.
