GM LS controller/harness to 3GHemi who has done it?
#1202626
03/24/12 05:22 PM
03/24/12 05:22 PM
Posts: 1,030 JAX FLA
Curt
JAX FLA
Don't want to spend 3 LARGE to get FAST engine management system. Any help? Curt Please keep this limited to GM LS systems, not interested in other systems. I believe I have seen a Magnum (LA) engine converted...
Oh yeah...THAT'S gonna leave a mark!
Re: GM LS controller/harness to 3GHemi who has done it?
[Re: Curt]
#1202627
03/24/12 05:36 PM
03/24/12 05:36 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
I wouldn't wanna tackle the wiring nightmare of adapting the LS Harness to a Dodge computer.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: DARTH V8Я]
#1202628
03/24/12 05:39 PM
03/24/12 05:39 PM
DaytonaTurbo
Manitoba, Canada
He would be using a reprogrammed LS computer. However for the cost associated with buying and retuning that GM ecu/harness I would be looking into an efi system like megasquirt. But since you don't want to hear about that, all I can say is good luck and it won't be as cheap or easy as you think.
[Re: DARTH V8Я]
#1202630
03/24/12 06:10 PM
03/24/12 06:10 PM
Curt
JAX FLA
The harness is really no big deal. The cam and crank sensors are what I am curious about. Durability and reliability is hard to beat with factory stuff. Parts failure fixing is just a parts house away. Chry is not fond of modding their software. Thanks Curt
[Re: Curt]
#1202631
03/24/12 06:27 PM
03/24/12 06:27 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
not sure the Chrysler sensors will send the proper signals to the GM ECU. I would look into that before I spent a nickle.
[Re: Curt]
#1202632
03/24/12 06:53 PM
03/24/12 06:53 PM
DARTH V8Я
Its a TRAP!
How many wires does the 3G hemi use @ the crank sensor?
[Re: Supercuda]
#1202633
03/24/12 07:05 PM
03/24/12 07:05 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I have a buddy thats done quite a bit of work with LS ECM's connected to different engines.. Mostly Lexus V-8's in drift vehicles.. Anyway the thing that took more sorting than anything else has been getting the crank angle sensor/trigger wheel properly synced, it is critical & he wound up machining three trigger wheel adapters before he got it right.... Since then it's just a program & he sends it to his CNC mill.. Strangely all the threads for the ECT knock sensors matched up, he uses the GM TB, he burns his own programs, has a load cell dyno & generally is a very sharp guy... if it took him three tries I don't know your background but I can tell you it isn't easy... But that said there are so many options in the GM ECM you can make it do practically anything...
