74 Charger Small Block K-Frame #1202554
03/24/12 02:22 PM
03/24/12 02:22 PM
WI, USA
rrehm Offline OP
rrehm  Offline OP
WI, USA
I am restoring a 74 Charger Small Block and I have been told that with an oil pan from a 400CI engine I would not have to change the K-frame. Is this a fact and if so does anyone know the oil pan factory number that will work or what year 400 oil pan will work?
Rick
Re: 74 Charger Small Block K-Frame [Re: rrehm] #1202555
03/24/12 04:14 PM
03/24/12 04:14 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
Are you putting in a big block?? or small block??
Yes the big block do have a different K frame.
The spool type mounts are in a different location.
I know one is for sale if needed.
IIRC,the oil pan is body specific (A/B/E/C,etc) to clear the steering.
Here is a link to help you tell the differences.
http://www.rosevillemoparts.com/reference_enginetrans3.php
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: 74 Charger Small Block K-Frame [Re: rrehm] #1202556
03/24/12 05:54 PM
03/24/12 05:54 PM
AndyF Offline
AndyF  Offline
A 400 is a big block in the Mopar world and the oil pan from a 400 is not going to fit on a small block Mopar.
If you're restoring a small block '74 Charger then it is probably a 360 engine and you'll need a 360 oil pan. Look at the ID stamp on the engine to tell which engine you have.
Re: 74 Charger Small Block K-Frame [Re: 68Cbarge] #1202557
03/24/12 06:34 PM
03/24/12 06:34 PM
WI, USA
rrehm Offline OP
rrehm  Offline OP
WI, USA
Thank You! I think I will be putting in a stoker 340 or 360 to replace the 318.
