70 Charger Modern HVAC Box under dash #1202540
03/24/12 01:41 PM
03/24/12 01:41 PM
Temple, Texas
scoutsr2 Offline OP
scoutsr2  Offline OP
Temple, Texas
So, I have heard of the dash units offerred by vintage and classic but it is my understanding that they are only produced for cars that were not original A/C cars. I have a 70 Charger that came with factory A/C. I would like to upgrade my under dash unit to one with modern servos. I have a friend that had to make a template to use on his car and the process was quite intense.
Does anyone make a unit that will fit where the existing unit went thru the firewall on factory A/C equipped cars?
Re: 70 Charger Modern HVAC Box under dash [Re: scoutsr2] #1202541
03/24/12 04:00 PM
03/24/12 04:00 PM
Andrewh Online content
Andrewh  Online Content
the ones that use the modern servos don't poke through the firewall like the older units.
the blower motors are more compact.
the only extra hole I had to drill was for the drain. the rest I did because it was easier for routing.
but to get it to mount I just built a plate to bolt the box to, and then ran bolts through the plate where the old blower motor mounted to the fire wall.
so the piece mounted in the factory holes.
I could adjust how high or low by mounting it differently on the plate.
it will not work with your original dash stuff though.
I thought about how to make buttons give the same resistance as pots, but it was a bit cost prohibitive and very low number production if I decided to have it made. wasn't worth the time to figure the rest of it out.
Re: 70 Charger Modern HVAC Box under dash [Re: Andrewh] #1202542
03/30/12 05:48 PM
03/30/12 05:48 PM
Temple, Texas
scoutsr2 Offline OP
scoutsr2  Offline OP
Temple, Texas
I dont suppose you have any pics of the plate you built and the finished product do you?
