Need Front Hub Torque Spec 07 Ram 1500 4x4 #1202537
03/24/12 01:23 PM
03/24/12 01:23 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
can someone help me out here. cant find anything on this. Need the hub torque spec for the three bolts that hold the hub in place and then how do I set the latger nut for the splined Axle?? Right Front if it matters!??!??!
Thanks Moparts
Thank you
Kiddart
Re: Need Front Hub Torque Spec 07 Ram 1500 4x4 [Re: Kiddart] #1202538
03/24/12 01:53 PM
03/24/12 01:53 PM
Mass. USA#1
hemi70 Offline
hemi70  Offline
Mass. USA#1
Hub to knuckle bolts are torqued to 120 ft. lbs.
Axle shaft nut is torqued to 185 ft. lbs.
Gary.
Re: Need Front Hub Torque Spec 07 Ram 1500 4x4 [Re: hemi70] #1202539
03/24/12 07:08 PM
03/24/12 07:08 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
Thanks a million!!! Moparts Rocks
Thank you
Kiddart
