03 dodge ram #1202441
03/24/12 11:44 AM
03/24/12 11:44 AM
IL us
I
ink Offline OP
ink  Offline OP
I
IL us
i am having a problem with the winshield wipers....they work except when you turn them off they are not returning to the down position.. they are staying up 1/4 way up windshield
any info is appricated
Re: 03 dodge ram [Re: ink] #1202442
03/24/12 11:53 AM
03/24/12 11:53 AM
md
mopars4ever Offline
mopars4ever  Offline
md
most likely will need to replace the wiper motor. i`m pretty sure the park circuit is part of the motor. maybe others will chime in that know more about it.
Re: 03 dodge ram [Re: mopars4ever] #1202443
03/25/12 01:18 AM
03/25/12 01:18 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Sounds like the wiper arm linkage at the motor has slipped causing the issue. remove the cowl cover and loosen the linkage nut at the motor, pop the linkage loose and push the wipers down and retighten the nut.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
