tranny numbers decode help #1202158
03/23/12 11:09 PM
03/23/12 11:09 PM
country
hemikev Offline OP
hemikev  Offline OP
country
Can any 1 help decode these numbers on tranny rail the engine and trans are replacements engine is 69 383 hp ( 9A278203 ) trans numbers i found are PK289 093L 1490 am i missing numbers do these make sence to any 1 thanx
Re: tranny numbers decode help [Re: hemikev] #1202159
03/23/12 11:26 PM
03/23/12 11:26 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
( 9A278203 )
From a 1969 B-body built at Lynch Road.
Re: tranny numbers decode help [Re: Alaskan_TA] #1202160
03/23/12 11:29 PM
03/23/12 11:29 PM
country
hemikev Offline OP
hemikev  Offline OP
country
are u saying tranny from 69 as well thanx T / A
Re: tranny numbers decode help [Re: Alaskan_TA] #1202161
03/24/12 01:04 AM
03/24/12 01:04 AM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
( 9A278203 )
383 HP, also same #s for an A12 440-6
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: tranny numbers decode help [Re: AZ_A12_BEE] #1202162
03/24/12 01:10 AM
03/24/12 01:10 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
( 9A278203 )
and a 440-4bbl car ...
Re: tranny numbers decode help [Re: JohnRR] #1202163
03/24/12 02:00 AM
03/24/12 02:00 AM
country
hemikev Offline OP
hemikev  Offline OP
country
Thanx You guys rock
Re: tranny numbers decode help [Re: hemikev] #1202164
03/24/12 12:08 PM
03/24/12 12:08 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
You are missing a couple of numbers....
PK = transmission assembly plant
289 2 093 = Part number for automatic transmission behind a late 68 model year or 69 383/440
L = appears to indicate an 'interim' part per TSB D68-21-3 TSB on Hamtramck Historical
the next four numbers = assembly date listed by a 10,000 day calendar date. The VIN is consistent with cars with an SPD of around 5/21 so if this transmission came with the engine, the transmission assembly date should be something that probably starts with 28XX.
followed by four digits indicating that specific transmission assembly number on that date.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: tranny numbers decode help [Re: 69CoronetRT] #1202165
03/24/12 05:54 PM
03/24/12 05:54 PM
country
hemikev Offline OP
hemikev  Offline OP
country
yes on the same pad there is a 5 13 looks like u guys are right again and yes on the rail there is a faint # 2 so number reads pk2892093L assuming there wasnt a vin on tranny in 69 ? thanks for lettin me pic ur brains take care...
Re: tranny numbers decode help [Re: hemikev] #1202166
03/24/12 06:07 PM
03/24/12 06:07 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
assuming there wasnt a vin on tranny in 69....
Yes. If it's a 69 model year transmission, there should be a VIN stamped on a pad on the passenger's side of the transmission. If it came out of a 68 model year car, there could be a VIN stamped on the upper center portion of the bell housing.
Seeking:
