INDY HI-PO hemi head #1201689
03/22/12 11:51 PM
03/22/12 11:51 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
Has anyone used these heads?
Re: INDY HI-PO hemi head [Re: robnbird] #1201690
03/22/12 11:59 PM
03/22/12 11:59 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
There are a lot of people asking questions on these heads. They sound like a good head, only time will tell. Tim
Re: INDY HI-PO hemi head [Re: astjp2] #1201691
03/23/12 12:12 AM
03/23/12 12:12 AM
tn
robnbird Offline OP
robnbird  Offline OP
tn
well I have these heads and Im on the second set of custom piston from weisco and it doesn't look like these will work.
Re: INDY HI-PO hemi head [Re: robnbird] #1201692
03/23/12 05:13 AM
03/23/12 05:13 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
trouble with the shape of the combustion chamber ???
home of the
Sox and Martin Hemi Duster
Re: INDY HI-PO hemi head [Re: robnbird] #1201693
03/23/12 07:35 AM
03/23/12 07:35 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
What's up with them?
Re: INDY HI-PO hemi head [Re: Dragula] #1201694
03/23/12 10:46 AM
03/23/12 10:46 AM
tn
robnbird Offline OP
robnbird  Offline OP
tn
I checked the clearance in the combustion chamber using clay. I installed the clay between the int and ex valves. pressed the piston down into the chamber. I have about 3/4 in clearance. I just don't think that is much compression
Re: INDY HI-PO hemi head [Re: robnbird] #1201695
03/23/12 01:13 PM
03/23/12 01:13 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
cc the heads and check the down fill in the cylinders for true compression ratio.
