difference between 1970 383 & 440 air grabber baseplate #1201493
03/22/12 06:04 PM
03/22/12 06:04 PM
Vancouver,Canada
70 Roadrunner* Offline OP
Vancouver,Canada
I bought a 70 RR...383 air grabber car last year and it came with a K&N air filter.I just bought a fram filter for it today which is the stock equivalent but it's about 1 1/2 inches taller than the K&N and of course now my hood won't close.My buddy that has the same car (no he isn't in town right now to measure the height of his) says I probably have a 440 baseplate.Can anyone tell me the depth from the cross- member on the 383 baseplate to the bottom?I think I'm sitting here with a 440 piece...this after I just restored it,primed,sanded and painted it...help!
Re: difference between 1970 383 & 440 air grabber baseplate [Re: 70 Roadrunner*] #1201494
03/22/12 06:09 PM
03/22/12 06:09 PM
Temple, Texas
scoutsr2 Offline
scoutsr2  Offline
Temple, Texas
Not sure of the measurement but sounds exactly right. B vs RB motor different base. I have a complete air grabber set up for a 71 RR and it is 383 only...or 400 I guess if you just wanted to.
Re: difference between 1970 383 & 440 air grabber baseplate [Re: 70 Roadrunner*] #1201495
03/22/12 06:28 PM
03/22/12 06:28 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You may have the wrong filter , a stock filter height is barely 3" and the 440 base is SHORTER than a 383 base because the 440 is taller than a 383 . You can put a 440 air cleaner on a 383 and close the hood , but you can't put a 383 base on a 440 without having an issue .
What intake do you have ?
Re: difference between 1970 383 & 440 air grabber baseplate [Re: scoutsr2] #1201496
03/22/12 06:31 PM
03/22/12 06:31 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
IIRC when I had my 71 RR there was about 3/4 to 1" difference in height difference. Post a pic. My K&N filter element is the same height as a Fram CA 322.
I am truckless..
Re: difference between 1970 383 & 440 air grabber baseplate [Re: 340SHORTY] #1201497
03/22/12 06:39 PM
03/22/12 06:39 PM
Vancouver,Canada
Vancouver,Canada
Baseplate measures 2 1/8 inches from bottom of baseplate crossmember to the table.The new Fram filter measures 3 1/2 inches but my old K&N filter is 2 5/8...anyone?Anyone?
Re: difference between 1970 383 & 440 air grabber baseplate [Re: 70 Roadrunner*] #1201498
03/22/12 06:43 PM
03/22/12 06:43 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
sounds kinda tall.
I am truckless..
Re: difference between 1970 383 & 440 air grabber baseplate [Re: 70 Roadrunner*] #1201499
03/22/12 06:50 PM
03/22/12 06:50 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what INTAKE do you have ? The fram is tall the K+N is short.
Re: difference between 1970 383 & 440 air grabber baseplate [Re: 340SHORTY] #1201500
03/22/12 06:51 PM
03/22/12 06:51 PM
Vancouver,Canada
Vancouver,Canada
What seems tall?Air filter or baseplate?
Re: difference between 1970 383 & 440 air grabber baseplate [Re: 70 Roadrunner*] #1201501
03/22/12 06:52 PM
03/22/12 06:52 PM
Vancouver,Canada
Vancouver,Canada
Sorry guys,it's a factory intake
Re: difference between 1970 383 & 440 air grabber baseplate [Re: 70 Roadrunner*] #1201502
03/22/12 07:00 PM
03/22/12 07:00 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Your base plate sounds like its taller than the 383 version. Maybe dart4forte will chime in. He has my old 71 RR.
I am truckless..
Re: difference between 1970 383 & 440 air grabber baseplate [Re: 70 Roadrunner*] #1201503
03/22/12 07:02 PM
03/22/12 07:02 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Your stock air filter is tall , I measure 3.5ish to the TOP of the crossbar on a 383 oval filter air cleaner I have.
I measured the air filter element in my unsilenced 69 air cleaner , which uses the same filter as the 70 fresh air, it's 2 5/8 overall.
Re: difference between 1970 383 & 440 air grabber baseplate [Re: JohnRR] #1201504
03/22/12 07:11 PM
03/22/12 07:11 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Picture from "Nicks Garage"
Might help you out.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: difference between 1970 383 & 440 air grabber baseplate [Re: hemi71x] #1201505
03/22/12 07:17 PM
03/22/12 07:17 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The easiest way to tell a 383 from 440 base is to set the carb horn on a flat surface, if the outer seal edge is off the flat surface it's a 383 unit, if it touches it's a 440.
All bets are off if it doesn't touch and the carb horn has been cut , I have one of those too ...
Re: difference between 1970 383 & 440 air grabber baseplate [Re: JohnRR] #1201506
03/22/12 07:21 PM
03/22/12 07:21 PM
hemi71x Offline
hemi71x  Offline
Picture #2 for reference, from "Nicks Garage"
Re: difference between 1970 383 & 440 air grabber baseplate [Re: hemi71x] #1201507
03/22/12 10:50 PM
03/22/12 10:50 PM
Vancouver,Canada
Vancouver,Canada
Guys thanks for all the input...I went with the 2 5/8 air filter and all is well...
