Re: '72 Satellite - Ready to rumble
[Re: rtman]
#1201383
03/22/12 03:38 PM
03/22/12 03:38 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Looks good and sounds like a great car! ....not so sure about the "great" Johnrr statement though..... Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: rtman]
#1201387
03/22/12 04:08 PM
03/22/12 04:08 PM
Posts: 1,120 MassHole Central
rtman
MassHole Central
Details: steel crank, Comp Cam (XE 262 ? or not), ported 452 heads, Edelbrock CH4B intake, Edelbrock Thunder 800 cfm w/electric choke, tti 2.5" exhaust w/H-pipe, 3.23 SG (clutch type) rear, 225-70 15s on front, 255-60 15s out back on cop vented wheels, MP electronic ignition,... I know I'm forgetting stuff...John will remember. Going to the dyno end of April for carb tuning. More pics and data then
[Re: rtman]
#1201389
03/22/12 06:02 PM
03/22/12 06:02 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Details: 76 440 block, stock stroke forged crank, Diamond CUSTOM quench dome forged Pistons ... ~9.5 compression w/.040 piston to head clearance ... swinging on K1 H beam rods, Paul Rossi Street Fighter 452 heads further enhanced/ported by Porter Racing Heads including the open part of the chambers being equalized in depth and shape for use with quench dome pistons, Comp Cams CUSTOM grind by Dwayne Porter ... NITRIDED, induction is a Edelbrock Thunder 800 cfm w/electric choke on top of a Edelbrock CH4B intake, exhaling thru stock HP manifolds... port matched ... connected to a tti 2.5" exhaust w/H-pipe, MP electronic ignition fires the mixture. Power is transfered thru a 727 stuffed w/ CRT valve body, 3.8(4.2??)lever, A+A ulitmate sprag w/a factory hi-stall converter, out back is an 8.75 w/a 3.23 SG (clutch type), it's rolling on greasy B.F. Goodrich Radial T/A's size 225-70 15s on front, 255-60 15s out back on cop vented wheels ...
[Re: rtman]
#1201391
03/23/12 09:02 PM
03/23/12 09:02 PM
DPelletier
Very nice! ....and it doesn't need RR badges to make it cool IMO. Dave
1974 'Cuda
