Oxygenated fuel question..rejetting for MATS?????
#1201305
03/22/12 10:23 AM
03/22/12 10:23 AM
Posts: 205 Chicago,Illinois
nosboy
Chicago,Illinois
I've came up with this bright idea and I am wondering if it's ONLY ME that thinks this way... I'm bring my 1973 Challenger to MOPARS AT THE STRIP this April to race with the " BIG BOYS"...My question is,, my engine is jetted to run around 600 foot elevation and i use KLOTZ 113 racing fuel.. Because Las Vegas Motor Speedway is around 3000 foot elevation,, does it MAKE SENSE to use VP 113 OXYGENATED FUEL???? I'm thinking the OXYGENATED fuel will solve the LACK OF OXYGEN at 3000 feet... I will LEAVE the jetting alone BECAUSE VP recommends BIGGER JETTING !!! Did I just STUMBLE onto this OR AM I DREAMING???? Thanks.. Gary Oles nosboy
Re: Oxygenated fuel question..rejetting for MATS?????
[Re: nosboy]
#1201306
03/22/12 01:40 PM
03/22/12 01:40 PM
Posts: 43,274 Bend,OR USA
Cab_Burge
Most oxgenated fuel has alcholol in it, correct? If so how much real compression does your motor have? I buy the local pump gas that does not have Ethanol alcholol in it so I can make more heat in the motor when the spark goes off, I jet for MPH I don't rejet my car going from 2500 Ft to 180 ft above sea level, it picks up around two tenths and 2 to 3 MPH in the 1/8 mile at sea level with no changes If your jetted dead nuts on for the perfect tune you may be a little rich at L.V., I think the track is closer to 2500 Ft than 3000 Ft Google Nellis Air Force Base elevation Its right across the street, maybe 100 to 200 FT lower than the drag strip is Al,Aguire, what is the track elevation there?
[Re: Dunnuck Racing]
#1201308
03/22/12 02:47 PM
03/22/12 02:47 PM
nosboy
Chicago,Illinois
I'm not looking at it like atmospheric pressure,, I'm looking at it as PARTS PER MILLION of OXYGEN !!! Less air = Less oxygen.. less oxygen = more fuel.. By using an oxygenated fuel,, I am reintroducing the LOST OXYGEN to the system.. The FUEL quantity will stay the same because I will NOT rejet... I ALSO don't want to travel with 15 or 20 gallons of fuel in the trailer.. I don't know WHAT THE LAWS are about fuel in containers in your trailer,, so,, I'd RATHER buy the fuel out there in Las Vegas !!!
[Re: nosboy]
#1201309
03/22/12 02:59 PM
03/22/12 02:59 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
the physical elevation of the Strip is right around 2000 ft...the corrected elevation will probably be over 2500 to 3500 depending on the temperature and barometer for MATS. http://airdensityonline.com/results/?trackname=Las%20Vegas%20Motor%20Speedwayyou can use the link above for reference.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: nosboy]
#1201310
03/22/12 03:33 PM
03/22/12 03:33 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
That is what I am trying to get at,you can't just pick and choose one way to look at it. You are dealing with both,lost oxygen molecules(parts per million,or however you want to look at it)AND loss of atmospheric pressure. These are the reason correction factors work the way they due,less oxygen,less pressure,air temperature,etc. all affect tuning. You can't just tune using one aspect of it to try and fix things. If you add an oxygenated fuel to help with the lack of oxygen,the other factors are still there and your tune up will still be off. I guess the point I am trying to make is that less pressure pushing the fuel through the carb will affect jetting and adding oxygenated fuel will not be the answer for all the factors involved. Keith
#1201311
03/22/12 04:20 PM
03/22/12 04:20 PM
nosboy
Chicago,Illinois
I think I understand a litle better.. I thought I could just change fuel and it would help... Considering I run KLOTZ 113,, would it be a good idea, considering that I am running PRO E.T> and it really doesn't matter if the car runs 10.0's instead of 9.70's,, would you think it's a good idea to run VP 114 or VP 110 or that VP 113 Oxygenated fuel???? Like I said,, I really didn't want to rejet if at all possible,, I just want to have fun at the MATS... WHICH FUEL DO I NEED TO ORDER???? Thanks again for your help !!! Gary Oles nosboy
[Re: nosboy]
#1201312
03/22/12 04:33 PM
03/22/12 04:33 PM
Cab_Burge
What is the actual, true mechaincal compressio ratio in your motor and which cylinder heads are you running, iron or aluminum? As far as transporting fuel in a enclosed trailer there are regulations on how much and what labeling that is required for transporting Hazardous materials As far as I'm concerned I'm not letting any law enforcement look in any of my vehicles or homes without a valid search warrent Labels or no labels Besides, a full tank of fuel is a lot safer than a half or almost empty gas tank Less sloshing hence less fumes, less chance for static ignition Hopefully I'll see you there with a full tank of fuel in my car and two full containers of Oregon non ethanol pump premium 91 octane gasoline in the trailer
[Re: nosboy]
#1201316
03/22/12 11:20 PM
03/22/12 11:20 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Your allowed to haul 110 gals in the proper drums with ground straps on them and the drums secured (proper drums will have the labeling on them to show what it is)
[Re: nosboy]
#1201317
03/23/12 12:20 AM
03/23/12 12:20 AM
Cab_Burge
True compression ratio is 13.1 to 1 and the heads are Indy 440-1CNC325. the motor makes 775hp,,,
I have ran motors like yours there, I selected the VP C12, 110 octane if I'm remembering correctly. If you want a little more power with no jet changing buy the VP C14+
[Re: nosboy]
#1201318
03/23/12 01:06 AM
03/23/12 01:06 AM
Posts: 3,616 Riverside, Ca
G_bob
Riverside, Ca
I've got 12.9:1, dynoed at 770 @ sea level with victor max wedge heads. I haven't changed the jets since it was dynoed. I don't even remember what sizes are in it. I'd have to pull the dyno sheets to see. I run sunoco 110 down here at fontana (1100 ft) and same up in vegas. Best of 9.92 at fontana and run mid 10.0's in vegas.
Maybe one of these days I'll try tuning for best ET.
