what foam to use in heater box ? #1201211
03/22/12 02:00 AM
03/22/12 02:00 AM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi
replacing evaporator in m truck and need some new foam seals ?
where do you get the right stuff to reseal the box and doors inside ?
thank you !
Re: what foam to use in heater box ? [Re: calrobb2000] #1201212
03/22/12 09:47 PM
03/22/12 09:47 PM
Crofton, MD
bri440 Offline
bri440  Offline
Crofton, MD
There are heater box gasket kits available online. Not exactly cheap, but if you have the heater box out, might be a good time to replace everything. Most of the gaskets are made from 1/8 foam so you could find a sheet of foam and try to make you own gaskets.
Re: what foam to use in heater box ? [Re: calrobb2000] #1201213
03/22/12 11:02 PM
03/22/12 11:02 PM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
I bought mine from, I think it was Detroit Muscle. It was a great kit. Not sure if you are talking about something they make though.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: what foam to use in heater box ? [Re: calrobb2000] #1201214
03/23/12 08:26 AM
03/23/12 08:26 AM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
here is a link.
http://www.detroitmuscletechnologies.com/
get in contact for what you are looking for. he always is looking for new patterns for new products. if you don't have the old ,maybe he will even provide some material to make your own.
