R1A Block Oil Pan #1201155
03/21/12 11:26 PM
03/21/12 11:26 PM
People's Republic of Mass.
Belvedere2 Offline OP
I bought an R1A block and need to change the oil pan. I've read that it should be a 360 style pan. If I drop the pan is there an easy way to tell if it's a 360 or 340 style pan? Thanks.
Re: R1A Block Oil Pan [Re: Belvedere2] #1201156
03/22/12 06:48 AM
03/22/12 06:48 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
The sealing area at the rear main cap for the pan is smaller for
the 360 compared to the 318/340. I can get you measurements
tonight after work, if somebody doesn't post them.
Most R-blocks use the 360 pan.
Re: R1A Block Oil Pan [Re: S/ST 3040] #1201157
03/22/12 10:39 AM
03/22/12 10:39 AM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
You should be able to visually look at the pan without removing it to tell. If the front and rear sealing area are the same size it's a 318/340 rear cap. If it's smaller in the rear it's a 360 rear cap.
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: R1A Block Oil Pan [Re: S/ST 3040] #1201158
03/22/12 01:21 PM
03/22/12 01:21 PM
Thanks. Thats what I figured. There's a 360 Milodon for sale here and I didn't want to guess on it.
Re: R1A Block Oil Pan [Re: Plumb Wired] #1201159
03/22/12 01:23 PM
03/22/12 01:23 PM
Hopefully I can do that. It's a Charlies pan so it has that wide flat area in the back.
Re: R1A Block Oil Pan [Re: Belvedere2] #1201160
03/22/12 02:23 PM
03/22/12 02:23 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I got an adaptor from Ryan J to use a 340 pan on a 360 block. Its a silicone mess but it works just fine and doesn't leak. Just letting you know of the option.
68 Barracuda Formula S 340
Re: R1A Block Oil Pan [Re: Bad340fish] #1201161
03/24/12 04:13 PM
03/24/12 04:13 PM
Looks like it's a 340 pan. Gotta love Mopar!
Re: R1A Block Oil Pan [Re: Belvedere2] #1201162
03/24/12 07:22 PM
03/24/12 07:22 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
The R1A that I had used a 340 pan
Re: R1A Block Oil Pan [Re: 340RICK] #1201163
03/24/12 09:39 PM
03/24/12 09:39 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Me too. The oil pan "Adapter" works just fine.
