TQ vs AFB vs AVS #120107
09/13/08 03:57 PM
09/13/08 03:57 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
Which one would be the best all-around carb for a 100% street driven '66 300 383/727?
Re: TQ vs AFB vs AVS [Re: jeebis44] #120108
09/13/08 04:25 PM
09/13/08 04:25 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
properly set up TQ, no comparison in idle, throttle response or ultimate CFM.
Re: TQ vs AFB vs AVS [Re: pishta] #120109
09/13/08 05:07 PM
09/13/08 05:07 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Yep; i'll take the thermoquad over the other two. The one problem is the availability of parts for the thermoquad. When properly set up and tuned the thermoquad all the way. Dave
Re: TQ vs AFB vs AVS [Re: jeebis44] #120110
09/14/08 12:50 PM
09/14/08 12:50 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You should just use a Holley , a TQ will burn your car to the ground ...
Re: TQ vs AFB vs AVS [Re: JohnRR] #120111
09/14/08 01:08 PM
09/14/08 01:08 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
What world are you living in? I suppose a Holley never had a float stick and dump gas all over the place? On a street car, I run nothing but Thrmoquads
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: TQ vs AFB vs AVS [Re: 69L78Nova] #120112
09/14/08 01:22 PM
09/14/08 01:22 PM
I'm assuming stock square bore intake. Either afb or avs. AVS was use in the emissions era & was calibrated accordingly but can be made to run but with everything being equal I would prefer an AFB or an edelbrock replacement for performance.
Re: TQ vs AFB vs AVS [Re: RapidRobert] #120113
09/14/08 02:35 PM
09/14/08 02:35 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
Robert,
FWIW - AVS's aren't only from emissions era. I've pulled a few of them out of '68 383/727 C-bodies, like Sport Furies.
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: TQ vs AFB vs AVS [Re: 67SATisfaction] #120114
09/14/08 02:43 PM
09/14/08 02:43 PM
so there were no carb calibration mods for emission purposes in '68? I was thinking that from 68 onward that they were all tweaked to some extent(gov't regs).
Re: TQ vs AFB vs AVS [Re: 67SATisfaction] #120115
09/14/08 02:49 PM
09/14/08 02:49 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
I HAD a edelbrock AFB 800 cfm carb that never ran good no matter how it was jetted. Got a NOS thermoquad and sent it to Demonsizzler....WOW ! My car never ran so smooth..never loads up ..it just rips ! I gained 4mpg at the same time. I here that the AVS 800 edelbrock IS a better carb than the AFB but I would get a thermoquad for a street strip type Mopar if you could.
Re: TQ vs AFB vs AVS [Re: THESHAKERPROJECT] #120116
09/14/08 03:05 PM
09/14/08 03:05 PM
If he has a later stock or an aftermarket spreadbore intake then as said a thermoquad is vastly superior & demonsizzler is the man.
Re: TQ vs AFB vs AVS [Re: RapidRobert] #120117
09/14/08 06:22 PM
09/14/08 06:22 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
Thanks for the input. Looks like a DemonSizzled TQ is the way to go. What would be the best intake?
(I currently have the stock squarebore intake- looks like the secondary holes are just a tad bigger than the primaries) Will the AFB linkages bolt directly up to a TQ or will they have to be modified?
-Chris
Re: TQ vs AFB vs AVS [Re: jeebis44] #120118
09/14/08 06:31 PM
09/14/08 06:31 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
For HP and good street-manners WITH decent MPG ... the TQ is as close to FI as you will get using a carb.
BUTTTTT there is no need to spend a ton of money on an expensive rebuilder. Just pick-up a BIG Chrysler service manual and you are good-to-go.
As far as an intake choice ... your application ? .. an Eddy Streetmaster.
Re: TQ vs AFB vs AVS [Re: dOoC] #120119
09/14/08 06:43 PM
09/14/08 06:43 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If you have a smogger era TQ (9000 series), you will definitely want to send it to demonsizzler to get rewored.
Re: TQ vs AFB vs AVS [Re: DaytonaTurbo] #120120
09/15/08 09:15 AM
09/15/08 09:15 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
