NEVER believe a SRT Engineer #1201079
03/21/12 09:46 PM
03/21/12 09:46 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
The crank will physically fit..yes...however you'll crash valves without a reduction in valve lift. The Tone Rings have been changed...yes they are interchangeable...make sure you change your crank sensor too if you do that.
Originally Posted by mattw
Will a 6.4 production crankshaft fit in a 5.7 6.1 2003-2008 hemi?
I know the crankshaft toner ring has been changed since 2009.
Will the toner rings from earlier hemi bolt on a production 6.4 crankshaft?
Matt
I posted this to a bunch of SRT engineers and their response was written on top.
Thanks to Steff i found out that the production 6.4 crankshaft has to be machined on the snout to make the early 5.7 6.1 hemi timing chain work. Plus on top of that, found out the toner rings are 3 bolt (early), 4 bolt late model.
How the hell does that make them interchangable.
Re: NEVER believe a SRT Engineer [Re: MattW] #1201080
03/22/12 08:22 AM
03/22/12 08:22 AM
NY usa
540challenger Offline
NY usa
Matt
Thanks for the post and trying to work it out.
This puts me on hold now on my 3rd gen swap.
My plan was to run a older 5.7 computer and change the tone ring over to the older since i would be using a production 6.4L
Great well not that I could get it moving on the project anyways as there still don't have any 6.4 avail,
Re: NEVER believe a SRT Engineer [Re: 540challenger] #1201081
03/22/12 09:58 AM
03/22/12 09:58 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Matt
Machining the front snout is no big deal and I suppose you could make a billet wheel to fit the 6.4 and run the older computer.
I THINK I was pretty specific in my question.
I think the SRT group need some old fashion hot rodders
Like stick the 6.4 in everything. IMPO you dont need the SRT badging on everything.
Everything about an SRT product is different. Bearing, caliper, rotor, upper lower control arms steering interior.
Take the 6.4 and put it into the ram 1500. Beef up the tranny and nothing else. Matt
Re: NEVER believe a SRT Engineer [Re: MattW] #1201082
03/22/12 12:25 PM
03/22/12 12:25 PM
Tulsa oklahoma USA
2
2734bbl Offline
2734bbl  Offline
Tulsa oklahoma USA
Aww man !! so much for a cheaper alternative for stroker parts.
I wonder if the 3 bolt tone ring can be welded up and the correct bolt pattern drilled into it?
Re: NEVER believe a SRT Engineer [Re: 2734bbl] #1201083
03/22/12 01:29 PM
03/22/12 01:29 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
My 08' 6.1 Crank has 4 screws for the tone ring.
Re: NEVER believe a SRT Engineer [Re: STEFF] #1201084
03/22/12 02:29 PM
03/22/12 02:29 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
I got a 2006 5.7 and it is showing 3 bolts MAYBE theres hope.
So use a toner ring from an 6.1 crank.
Re: NEVER believe a SRT Engineer [Re: STEFF] #1201085
03/22/12 02:43 PM
03/22/12 02:43 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
How many teeth on your 6.1. 3 bolt is 32 and 4 bolt is 52 IIRC.
Re: NEVER believe a SRT Engineer [Re: MattW] #1201086
03/22/12 04:34 PM
03/22/12 04:34 PM
STEFF Offline
STEFF  Offline
I'll check it when I get home this evening.
Re: NEVER believe a SRT Engineer [Re: STEFF] #1201087
03/22/12 08:45 PM
03/22/12 08:45 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
This is what burns me up about chrysler, they can't make just one hemi engine and then come out with upgraded parts that fits all. Not enough money that way so you sell what you got and buy the new stuff. We're all billionaires!
Re: NEVER believe a SRT Engineer [Re: cudaman1969] #1201088
03/22/12 08:48 PM
03/22/12 08:48 PM
STEFF Offline
STEFF  Offline
08' 6.1 Tone Wheel: 4 Bolt Mtg.............31 Small Teeth, One Large Tooth
Re: NEVER believe a SRT Engineer [Re: STEFF] #1201089
03/22/12 09:29 PM
03/22/12 09:29 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Same as my 5.7 with 3 bolts.
So the 6.1 ring fixes the 6.4 problem but the toner ring does not come seperate you need to purchase a crank.
Maybe a market for this item.
Thanks Steff this is the stuff that really helps
Re: NEVER believe a SRT Engineer [Re: MattW] #1201090
03/22/12 09:44 PM
03/22/12 09:44 PM
STEFF Offline
STEFF  Offline
No problem Matt.
Re: NEVER believe a SRT Engineer [Re: STEFF] #1201091
03/23/12 12:18 PM
03/23/12 12:18 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Learn something new everyday!
The one 6.4 that I worked on, really did have a 3 bolt
tone ring
It was a pre-production mule that had been rode hard and put away in a basket, and I've only rebuilt that one....no production engines.
I'm going to take a wild guess:
Maybe whoever was on that chat session saw the engine around the same timeframe as the one I saw, and they assumed it didn't change...
At any rate: oopsie...
Summary:
I'm glad you didn't ask me, I would have told you the same thing
Rich H.
Esse Quam Videri
Re: NEVER believe a SRT Engineer [Re: ZIPPY] #1201092
03/23/12 08:13 PM
03/23/12 08:13 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
tone ring
Summary:
Maybe I went overboard Possibly moon cycle.
Any rate contacted K1 and bought one of there 4 bolt 32 teeth Reluctor wheel AKA toner ring.
Will see if it bolts to the 6.4 crankshaft.
Got a couple of other questions.
1 On a 06 5.7 what is the 3 prong plug at the rear of the block. Looks like a block heater BUT does not enter the coolant system.
2 The head bolts ingage into the block at a depth of 1.5 inches. Was this done to limit distortion.
Re: NEVER believe a SRT Engineer [Re: MattW] #1201093
03/23/12 08:21 PM
03/23/12 08:21 PM
Burlington, Ontario Canada
Dave_S Offline
Dave_S  Offline
that plug is a block heater. It doesn't go into the water jacket...one less potential leak.
Dave Stillie
'73 Swinger
5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: NEVER believe a SRT Engineer [Re: Dave_S] #1201094
03/23/12 08:43 PM
03/23/12 08:43 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Thx
Re: NEVER believe a SRT Engineer [Re: MattW] #1201095
03/28/12 11:50 AM
03/28/12 11:50 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
So I contacted Wiseco and purchase their 32 4 bolt reluctor wheel.
IT FITS the 6.4 production crankshaft. Wiseco part # TR-32
Now i'm off to by a lotto ticket
Re: NEVER believe a SRT Engineer [Re: MattW] #1201096
03/28/12 03:54 PM
03/28/12 03:54 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Nice to know the aftermarket is supporting those
Re: NEVER believe a SRT Engineer [Re: MattW] #1201097
03/28/12 04:35 PM
03/28/12 04:35 PM
New York
polyspheric Offline
polyspheric  Offline
New York
They have to use up the smaller motors.
Boffin Emeritus
Re: NEVER believe a SRT Engineer [Re: polyspheric] #1201098
03/28/12 04:38 PM
03/28/12 04:38 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
