NEVER believe a SRT Engineer
#1201079
03/21/12 09:46 PM
03/21/12 09:46 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
The crank will physically fit..yes...however you'll crash valves without a reduction in valve lift. The Tone Rings have been changed...yes they are interchangeable...make sure you change your crank sensor too if you do that. Originally Posted by mattw Will a 6.4 production crankshaft fit in a 5.7 6.1 2003-2008 hemi? I know the crankshaft toner ring has been changed since 2009. Will the toner rings from earlier hemi bolt on a production 6.4 crankshaft? Matt I posted this to a bunch of SRT engineers and their response was written on top. Thanks to Steff i found out that the production 6.4 crankshaft has to be machined on the snout to make the early 5.7 6.1 hemi timing chain work. Plus on top of that, found out the toner rings are 3 bolt (early), 4 bolt late model. How the hell does that make them interchangable.
Re: NEVER believe a SRT Engineer
[Re: MattW]
#1201080
03/22/12 08:22 AM
03/22/12 08:22 AM
Posts: 2,826 NY usa
540challenger
NY usa
Thanks for the post and trying to work it out.
This puts me on hold now on my 3rd gen swap.
My plan was to run a older 5.7 computer and change the tone ring over to the older since i would be using a production 6.4L
Great well not that I could get it moving on the project anyways as there still don't have any 6.4 avail,
[Re: 540challenger]
#1201081
03/22/12 09:58 AM
03/22/12 09:58 AM
MattW
Ontario Canada
Machining the front snout is no big deal and I suppose you could make a billet wheel to fit the 6.4 and run the older computer. I THINK I was pretty specific in my question. I think the SRT group need some old fashion hot rodders Like stick the 6.4 in everything. IMPO you dont need the SRT badging on everything. Everything about an SRT product is different. Bearing, caliper, rotor, upper lower control arms steering interior. Take the 6.4 and put it into the ram 1500. Beef up the tranny and nothing else. Matt
[Re: MattW]
#1201082
03/22/12 12:25 PM
03/22/12 12:25 PM
Posts: 155 Tulsa oklahoma USA
2734bbl
Tulsa oklahoma USA
Aww man !! so much for a cheaper alternative for stroker parts. I wonder if the 3 bolt tone ring can be welded up and the correct bolt pattern drilled into it?
[Re: STEFF]
#1201084
03/22/12 02:29 PM
03/22/12 02:29 PM
MattW
Ontario Canada
My 08' 6.1 Crank has 4 screws for the tone ring.
I got a 2006 5.7 and it is showing 3 bolts MAYBE theres hope. So use a toner ring from an 6.1 crank.
[Re: STEFF]
#1201085
03/22/12 02:43 PM
03/22/12 02:43 PM
MattW
Ontario Canada
How many teeth on your 6.1. 3 bolt is 32 and 4 bolt is 52 IIRC.
[Re: STEFF]
#1201089
03/22/12 09:29 PM
03/22/12 09:29 PM
MattW
Ontario Canada
08' 6.1 Tone Wheel: 4 Bolt Mtg.............31 Small Teeth, One Large Tooth
Same as my 5.7 with 3 bolts. So the 6.1 ring fixes the 6.4 problem but the toner ring does not come seperate you need to purchase a crank. Maybe a market for this item. Thanks Steff this is the stuff that really helps
[Re: STEFF]
#1201091
03/23/12 12:18 PM
03/23/12 12:18 PM
Posts: 17,876 S.E. Michigan
ZIPPY
S.E. Michigan
Learn something new everyday! The one 6.4 that I worked on, really did have a 3 bolt tone ring It was a pre-production mule that had been rode hard and put away in a basket, and I've only rebuilt that one....no production engines. I'm going to take a wild guess: Maybe whoever was on that chat session saw the engine around the same timeframe as the one I saw, and they assumed it didn't change... At any rate: oopsie... Summary: I'm glad you didn't ask me, I would have told you the same thing
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#1201092
03/23/12 08:13 PM
03/23/12 08:13 PM
MattW
Ontario Canada
Maybe I went overboard Possibly moon cycle. Any rate contacted K1 and bought one of there 4 bolt 32 teeth Reluctor wheel AKA toner ring. Will see if it bolts to the 6.4 crankshaft. Got a couple of other questions. 1 On a 06 5.7 what is the 3 prong plug at the rear of the block. Looks like a block heater BUT does not enter the coolant system. 2 The head bolts ingage into the block at a depth of 1.5 inches. Was this done to limit distortion.
[Re: MattW]
#1201093
03/23/12 08:21 PM
03/23/12 08:21 PM
Posts: 344 Burlington, Ontario Canada
Dave_S
that plug is a block heater. It doesn't go into the water jacket...one less potential leak.
Dave Stillie '73 Swinger 5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4 Mega-Squirt EFI [email]8.93@149 [/email]
[Re: MattW]
#1201095
03/28/12 11:50 AM
03/28/12 11:50 AM
MattW
Ontario Canada
So I contacted Wiseco and purchase their 32 4 bolt reluctor wheel. IT FITS the 6.4 production crankshaft. Wiseco part # TR-32 Now i'm off to by a lotto ticket
[Re: MattW]
#1201097
03/28/12 04:35 PM
03/28/12 04:35 PM
Posts: 4,209 New York
polyspheric
New York
They have to use up the smaller motors.
Boffin Emeritus
[Re: MattW]
#1201100
03/28/12 05:47 PM
03/28/12 05:47 PM
ZIPPY
S.E. Michigan
Never seen that on the pistons but in the interest of full disclosure will mention I have only built the 2008-down 5.7s. There was only two PNs for piston and rod assy's, left and right bank.
Bearings are another story though, different letter codes are used for the bearings so the clearance can be fine tuned slightly.
Rich H.
Esse Quam Videri
[Re: MattW]
#2369265
09/12/17 08:58 AM
09/12/17 08:58 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
the area behind the timing gear/oil pump drive is what needs to be machined. Blue back ground photo is 03-08 crank The other is a VVT crank.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: Paul_Fancsali]
#2369534
09/12/17 05:52 PM
09/12/17 05:52 PM
dogdays
It shouldn't be different in Canada, maybe it is: But in the USA, TONER is what you put in a Xerox machine.
A TONE RING is what through some pickup device, tells the computer how fast the shaft is turning and in some cases, where it is on the rotation.
And I thought it was just a couple of days ago where the conversion tone rings were mentioned and their suppliers specified.
All these different tooth counts make no real sense, when Electromotive standardized the 60 - 2 tooth wheel around 15 years ago.
R.
[Re: MattW]
#2370096
09/13/17 03:00 PM
09/13/17 03:00 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
No where near as bad as ford yet but they are trying.
This should be in the Gen III area, good info here.
