New axels are very tight #1201040
03/21/12 08:55 PM
03/21/12 08:55 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
I recently replaced my stock axels with axels from Dr Diff and green bearings I also went to a spool and replaced all bearings in my 8.75
they turn but are very stiff. I ve also put on my brake drum and wheel and snugged up the lug nuts and it's even harder to turn the wheel by hand(The car is in neutral) Is this normal when going with all new bearings?
Re: New axels are very tight [Re: flatiron] #1201041
03/21/12 10:48 PM
03/21/12 10:48 PM
Disconnect the driveshaft and try that first
Re: New axels are very tight [Re: Cab_Burge] #1201042
03/22/12 12:04 AM
03/22/12 12:04 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
maybe your new "axels" are the wrong "axles"
I am truckless..
Re: New axels are very tight [Re: flatiron] #1201043
03/22/12 12:14 AM
03/22/12 12:14 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I would question this before the new axles. I only say this because you don't sound sure of what is going on. Did the pinion turn freely after changing the pinion bearings,then it got hard to turn when the spool was installed? Did everything turn freely before the axles were installed? Just asking to see if you tried it this way as things went together.
Keith
Re: New axels are very tight [Re: Dunnuck Racing] #1201044
03/22/12 12:42 AM
03/22/12 12:42 AM
Keith
Keith has a a point, OP what third member casting number are you using, 741,742 or the dreaded 489 with the crush sleeve? it makes a difference
Re: New axels are very tight [Re: flatiron] #1201045
03/22/12 10:25 AM
03/22/12 10:25 AM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Also a spool and green bearing are much less forgiving than a differential and stock bearings when you have a bent housing. If there are no center section issues then I would start looking for a bent housing by using a housing narrowing jig.
Re: New axels are very tight [Re: Cab_Burge] #1201046
03/22/12 04:50 PM
03/22/12 04:50 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Keith
iT'S A 489 with the sleeve to elimante the crush sleeve. I found part of the problem the counter bore in the new drum was tight up against the backing plate. So it looks like I may have to shim the drum out a bit from the axel flange. The assembly is still fairly tight even with out the drum. I also guess my lack of experince doesn't help either. I just expect things to turn more freely
Re: New axels are very tight [Re: flatiron] #1201047
03/22/12 05:00 PM
03/22/12 05:00 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Maybe the guy who installed and setup the new bearings has put too much preload on the bearings?
I just installed a pair of DrDiff-axles in my self-narrowed 8-3/4" A-body housing and yes, everything feels 'tight', but not hard to turn or feel like binding.
Have your drums, brakes and rear axle checked over by someone experienced. Spacing out a drum for it to clear the backingplate sounds flakey in more ways then one. Something's not right.
Re: New axels are very tight [Re: BigBlockMopar] #1201048
03/22/12 09:10 PM
03/22/12 09:10 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
The groove in the back side of the brake drums where not machined deep enough.
