Gas Tanks - To Paint or Not to Paint? What do you do? #1200976
03/21/12 07:31 PM
03/21/12 07:31 PM
Colorado
CuriousYella70 Offline OP
Colorado
I just got a new gas tank for my 70 Duster. What do you guy's do? Do you leave them natural or do you paint them? If you paint them, what color do you paint them?
Thanks guys!
Re: Gas Tanks - To Paint or Not to Paint? What do you do? [Re: CuriousYella70] #1200977
03/21/12 07:55 PM
03/21/12 07:55 PM
california
Mr D21 Offline
Mr D21  Offline
california
Since they originally came natural and you bought a new one - why would you paint it ??
Re: Gas Tanks - To Paint or Not to Paint? What do you do? [Re: Mr D21] #1200978
03/21/12 07:59 PM
03/21/12 07:59 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
No way would I paint a brand new tank.
Re: Gas Tanks - To Paint or Not to Paint? What do you do? [Re: burdar] #1200979
03/21/12 11:08 PM
03/21/12 11:08 PM
WI
RestoRick Offline
RestoRick  Offline
WI
Re: Gas Tanks - To Paint or Not to Paint? What do you do? [Re: RestoRick] #1200980
03/22/12 10:42 AM
03/22/12 10:42 AM
Colorado
Colorado
I wasn't 100% on whether or not tanks were left natural or if they were painted. Clearly, they are left natural looking lol. Thanks for the help - I appreciate it!
Re: Gas Tanks - To Paint or Not to Paint? What do you do? [Re: RestoRick] #1200981
03/22/12 11:36 AM
03/22/12 11:36 AM
Ball Ground GA
TrueTripleX Offline
TrueTripleX  Offline
Ball Ground GA
RPM
Out of curiosity, what would you paint this with? I have a older, but solid tank that could use some cosmetic help before it goes back on the car. Any suggestions Rick as to how to dress it up?
Re: Gas Tanks - To Paint or Not to Paint? What do you do? [Re: TrueTripleX] #1200982
03/22/12 12:21 PM
03/22/12 12:21 PM
WI
RestoRick Offline
RestoRick  Offline
WI
You can't paint over RPM. (I don't think that's what you meant, but in case anyone does )
A fine metallic silver paint is one option.
Another suggestion would be the PPG Vibrance Collection's "Liquid Metal". I haven't seen it in
person, but it looks like it would have that bright tin look.
The most authentic look, would be to have the tank tin plated.
Rick
Re: Gas Tanks - To Paint or Not to Paint? What do you do? [Re: RestoRick] #1200983
03/22/12 12:31 PM
03/22/12 12:31 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Rick
Well sort of; although the tanks are originally formed (stamped) out of galvanized sheet, having it zinc plated now would mean using a hot dip galvanized process (like a boat trailer for eg.) which has quite a different look from regular galvazized sheet.
It's a moot point; unless you have a car that there is no replacement tank for, it'd be cost prohibitive to perform any hot zinc coating process.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Gas Tanks - To Paint or Not to Paint? What do you do? [Re: DPelletier] #1200984
03/22/12 03:26 PM
03/22/12 03:26 PM
WI
RestoRick Offline
RestoRick  Offline
WI
In the context of the conversation...
the most authentic available for his situation of
refurbishing his existing tank....
tin plating looks pretty close to the original coating.
There's at least one company I'm aware of that will strip & tin plate your original tank.
It's been awhile since I had one done, so I don't know where the cost comes out compared to buying a repro tank. It's more for the person who wants to keep the original tank for originality sake or has a tank that's not reproduced.
Re: Gas Tanks - To Paint or Not to Paint? What do you do? [Re: RestoRick] #1200985
03/22/12 03:58 PM
03/22/12 03:58 PM
DPelletier Offline
DPelletier  Offline
Nobody in western Canada does that and the hot dipping process here is prohibitively expensive (and looks wrong). If there is someone that does actual tin coating for a reasonable price, then I stand corrected and that would be an option.....though for most of us getting a new spectra tank is the way to go, both for looks and $$$$
Re: Gas Tanks - To Paint or Not to Paint? What do you do? [Re: DPelletier] #1200986
03/22/12 04:21 PM
03/22/12 04:21 PM
Colorado
Colorado
http://www.ebay.com/itm/Mopar-68-69-70-D...=item27b70bf9bc
That's the one I purchased for my 70 Duster. It's not a perfect restoration but wanted something better then my original - which is dented and was painted at some point so when gas hits it, it tends to bubble up and look horrible.
When i got it in, there are a few small scrapes on it and that's why I asked about painting or protecting the original zinc finish.
Re: Gas Tanks - To Paint or Not to Paint? What do you do? [Re: CuriousYella70] #1200987
03/22/12 04:48 PM
03/22/12 04:48 PM
PEI Canada
chromedome426 Offline
PEI Canada
Has anyone ever tried spraying clear coat on a new tank to keep it from rusting? Would it even stick to the bare metal?
Re: Gas Tanks - To Paint or Not to Paint? What do you do? [Re: chromedome426] #1200988
03/22/12 07:00 PM
03/22/12 07:00 PM
Dandridge TN
Dabee Online content
Dabee  Online Content
Dandridge TN
Yes, I clear coated the new tank I installed in my 69 Bee with POR 15 clear. That was 21 years ago and the tank still looks new.
Re: Gas Tanks - To Paint or Not to Paint? What do you do? [Re: RestoRick] #1200989
03/23/12 12:03 AM
03/23/12 12:03 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Gas tanks were and are made of terne sheet, which is cold rolled steel sheet hot dipped in an alloy of lead-tin. Originally it was 80% lead, 20% tin, the recipe for solder. More recently the lead has been replaced with zinc, in a ratio of 50% zinc, 50% tin, according to Wikipedia. But ASTM A308, "Standard Specification for Steel Sheet, Terne (Lead-Tin Alloy) Coated by the Hot-Dip Process" still exists.
It says, "This specification covers sheet steel in coils and cut lengths coated with lead-tin alloy by the hot-dip process. This material is commonly known as terne and is used where ease of solderability and a degree of corrosion resistance are desirable. It is especially suitable where resistance to gasoline is required."
I'll bet Chrysler Corp gas tanks were made of 80% lead-tin in the muscle car days. More recently the Canadian gas tank maker Spectra says they are using Ni-terne sheet, which is steel sheet flash coated with nickel before hot dipping in terne metal, but they don't say what alloy of lead-tin (or zinc) is in the terne metal. I believe most all the new repro tanks available on eBay, Quanta, etc. are made by Spectra.
As far as appearance, the original tanks were bright, bare metal, just like the new repro tanks. But over time, any alloy of lead-tin (or zinc) will darken with exposure to the atmosphere, so a preservative like RPM before installation makes sense to keep the bright bare metal look.
You can help brighten old lead or lead-tin by using a polishing powder wetted with vinegar on, for example, gas filler tubes. But don't do this on spangled galvanized or zinc coated steel - it destroys the spangled appearance making all the spangles the same metal color, rather than different shades of silver/gray. If the galvanized is not spangled, or you don't care about the spangles, this method will uniformly brighten it. Then, of course, it will darken again, if you don't put some kind of preservative on it.
