Help Needed ASAP! Code 41 and away from home!
#1200794
03/21/12 12:34 PM
03/21/12 12:34 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Guys I had the check engine light come on, so I pulled over and checked the codes.
41 came up and I have determined it is a charging related code.
Checked my connections, and all look good.
Symptoms:
When the check light came on, I scanned the gauges, everything looked OK. The volt meter was siting at 1/2 gauge, straight up, not in a charge, but not discharge.
As I exited the interstate, the volt gauge dropped, to a about 1/4 gauge, a fairly good discharge reading. If I bring the RPM up, the gauge would swing over to a charge (over half gauge) reading.
As I drove through the 35mph zone, it would stay on a discharge reading, but if I goosed it, it would again swing to charge.
When I parked, and went to N (no load on the engine/trans) the gauge would go to the middle at idle. If I slipped back into gear (Put the load back on the engine) it would again drop.
If i turned on headlights, during idle, no noticeable drop in volts was seen.
In my opinion the swinging of the gauge to the charge side is saying the alternator is working, my conclusion may be a faulty battery?
I have noticed that over the past two months when I was unable to drive the truck that the battery would discharge if I let it set for 5 or so days.
I would charge it up, and start the truck about once a week, and the battery would not seem to hold a charge without the aid of at least a 2A trickle charge.
What are your thoughts? I really need to get this fixed before I have to travel home tonight and need the headlights.
Truck is a 1993 Dodge W250 Diesel. So one good thing is the battery wont drain too quickly while running. All i really need to have is power enough to hold the fuel shutoff valve open. The diesel doesn't have any ignition draw.
Re: Help Needed ASAP! Code 41 and away from home!
[Re: JohnRR]
#1200797
03/21/12 02:41 PM
03/21/12 02:41 PM
Posts: 21,456 It's a dry heat
gtx6970
It's a dry heat
P 41 code is normally an oxygen censor code. I do not have my OBD 11 with me or any other code books for OBD 1 with me also. Since you have found the code I believe your truck runs OBD 1?
EVERYTHING before 1996 is ODB1
1995 Neons are OBD11
[Re: 666]
#1200799
03/21/12 02:48 PM
03/21/12 02:48 PM
Posts: 18,157 Mass
DAYCLONA
Mass
P41 is swapped 02 sensor code, bank 1, sensor 2, bank 2, sensor 2
OP, you either misread the code, or you have other issues
[Re: DAYCLONA]
#1200800
03/21/12 02:55 PM
03/21/12 02:55 PM
hp383
State of Confusion
http://www.dieselbombers.com/1st-generat...3-1st-gens.html
Chrysler Fault Code 41: Alternator field control circuit open or shorted
[Re: gtx6970]
#1200806
03/21/12 04:10 PM
03/21/12 04:10 PM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
[Re: 666]
#1200808
03/21/12 06:08 PM
03/21/12 06:08 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
Diesel charging issue. Let's keep the OBD stuff out of the way for the guy... As said, make sure you have good battery connections, alt connections and check the feed wire on the alt. If you can't find anything on the visual, time to get a voltmeter and check the battery(s) and the alt output. Thos old trucks tend to have cruddy connections after this much time and miles, so a good look/clean can often fix stuff.
