Re: Best Electronic Distributor set up for Mopar BB???
[Re: tboomer]
#1200731
03/21/12 12:25 PM
03/21/12 12:25 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Thats a hard one nothing wrong with a mopar dizzy for you cam install two light advance springs it will want close to full advance to idle right! http://chucker54.stores.yahoo.net/disadweigspr.htmlNothing wrong with a unilite last one I worked on had adjustments for the mechanical timing slots. I run long slots with the lightest springs for ease of starting ("I just used mopar/mr gasket springs") . (Some like to shorten the slots and use stock or medium springs that too does not let timing fall away to keep idle smooth! The msd is fine but I find their advance springs are too stiff so again i fit mopar springs to it for more idle advance with big cams! You can buy this adapter kit to use a RB 413/426/440 dizzy in a 383/400 B http://chucker54.stores.yahoo.net/rbtobbldiad.htmlThat way you are set up if you ever go RB
[Re: oldsklharo]
#1200732
03/21/12 01:43 PM
03/21/12 01:43 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
Although I am not a fan of the unilite line,if you have a complete setup,I would use it. Try to avoid mixing different coils/boxes/distributors,if possible. You can get a car to run decent by mixing products from different brands but I am dynoing different combination of coils with different boxes and distributors and you can gain or lose a lot of power and and drivability if the combination is wrong. I can't give away too much info yet due to what I am testing for a customer,but I will tell you this much,MP boxes work better without an MSD coil. I can get a smoother torque curve and more overall power with an Accel coil,and even a stock electronic ign. coil. Switch over to an MSD box,and the opposite is true.Different distributors have some suprising effects with the other parts too. I need to call Rick at Firecore and get one of his distributors and see how it compares. Keith
[Re: Dunnuck Racing]
#1200733
03/21/12 03:12 PM
03/21/12 03:12 PM
Posts: 5,907 Athens, Greece
Pyper70
Athens, Greece
I have to go along with the above post...Go with what you have. I had an MSD dizzy laying around for a 383. I called up MSD and told them I needed the shaft for a 440 and they wanted me to send it in. Somehow I suckered someone to sell me one. Put on the whole shebang from there...The MSD6-AL box, the timing control, and the MSD coil. When I put it altogether on the car (12 years ago) it was at the top of its game. The box, the timing control and the dizzy/cap/rotor are all still there and working along with the original plug wires. I am sure there are better and more cost effective units that have hit the market since then but I would use what I have
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: RapidRobert]
#1200735
03/21/12 09:17 PM
03/21/12 09:17 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
If it's a street/strip car, why not buy our Firecore ready to Run Distributor? It has a capacitive discharge ignition built right in it. plus, you can still maintain your stock cap if you wish. Dead-nuts timing all the way to 10k RPM.
Keith, please give me a call. We can discuss some options. Thank you for the interest. Rick
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: oldsklharo]
#1200736
03/22/12 02:03 AM
03/22/12 02:03 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
The Unilite will work. It has an adjustable curve, but you have to pull the dist apart to get at the advance. I also think the unilite is mechanical advance only with no vacuum advance? I run an old unilite on the 500" stroker, but it triggers a MSD box, so the electronics inside are not really seeing much current, so the electronics module does not get hot and it lasts a long time. I have an older Accel street billet dist on my 440 street car. It uses a magnetic pickup, has the built-in electronics, adjustable mechanical advance, and it also has vacuum advance. You may want to look at the FireCore Dist. It's pretty new. Not sure what the cost is on one though?
[Re: RapidRobert]
#1200737
03/22/12 09:56 AM
03/22/12 09:56 AM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
If you have difficulty going inside a regular dist by removing the clip then you may want a Mallory based MP unit with externally adjustable slots. You will be in & out of there several times if you want it spot on on the curve. #1 find your ideal initial w the vac gauge method then that tells you how much to shorten the slots. Could get it up & runnning with the points unit & you'll get the hang of getting the center clip in & out of there
Have you actually recurved one of these mallory based new MP units ?
[Re: RapidRobert]
#1200739
03/22/12 11:41 AM
03/22/12 11:41 AM
JohnRR
U.S.S.A.
No double R I have not but ain't that the main selling point of them is the easily adjustable slots . I have heard that touted multiple times & that was the basis of my recommendation.
No , the selling point is adjustable mechancial advance. You still have to take it apart to adjust and/or change the springs at least I couldn't easily see a way to do it without disassembly.
[Re: JohnRR]
#1200740
03/22/12 05:04 PM
03/22/12 05:04 PM
RapidRobert
Oh OK so it must come apart to ch the springs but you can access the torx head screws for the mech adv without tearing it down. Now I got it. Thank you double R.
[Re: RapidRobert]
#1200743
03/22/12 07:20 PM
03/22/12 07:20 PM
JohnRR
U.S.S.A.
Ummm, sort of , you can get to the screws but when you rotate it to adjust the advance with the tool they sell you can't see the screw to tighten it.
[Re: autoxcuda]
#1200744
03/22/12 07:21 PM
03/22/12 07:21 PM
JohnRR
U.S.S.A.
I have an MSD E-curve. Should work well with big block. It has built in rev limiter, electronic adjustable vacuum curve and timing curves. Just pop the cap and turn the dials with a pocket screwdriver.
Just don't use thier soild state coil with it (won't run). And it's a tight fit with an A-body and small block.
I don't think they make one for a big block or I would buy that .
