Re: IGNITION BOX QUESTION................................
[Re: Thumperdart]
#1200635
03/21/12 01:17 AM
03/21/12 01:17 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
my : As long as nothing was wrong with the 6a box, nothing. You'll gain an adjustable 2-step rev limiter and a few other adjustable features, but performance wise..... I'm guessing NADA.
[Re: Thumperdart]
#1200637
03/21/12 09:46 AM
03/21/12 09:46 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I have seen zero gain going from the old Mopar Gold Box, to a 6T, then to a digital seven. If you think there is something to gain there, drop the gap down .005 and see if it helps. If it does, I would be considering new wires, cap rotor and plugs before a new box.
[Re: monte442]
#1200642
03/22/12 07:56 AM
03/22/12 07:56 AM
Posts: 592 Sullivan, Ohio
Max Wedge Savoy
Sullivan, Ohio
MOst of the 7 series stuff is not for extended use,not good for the street. As far as going to a digital 6 the only thing you may gain is some headaches. After getting stuck several times with mine I sold it all,I have heard of several people having problems with them.
I have also heard the new digital boxes are not a serviceable item. If it goes poof you can stick it in file 13.
[Re: Thumperdart]
#1200643
03/22/12 09:48 AM
03/22/12 09:48 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
For your car you probably won't see any performance difference w/ a 7 series MSD. The bigger boxes do have more features though. I had bad luck w/ 2 different MSD Digital 6 boxes, sent em back and put my old 6AL back on.
