Re: F8 Plymouth Paint Code
[Re: cbusters]
#1200519
03/20/12 10:43 PM
03/20/12 10:43 PM
Posts: 749 NY
Beep Beep
NY
[Re: 6bblgt]
#1200523
03/21/12 06:13 AM
03/21/12 06:13 AM
Posts: 5,766 Port Huron, Michigan
MI_Custumz
There were 3 greens available on a Road Runner for the full 1969 model year. F3 - "frost green metallic" F5 - "limelight metallic" F8 - "ivy green metallic" & a mid-year special order "rallye green metallic" usually with code 99.
Those are the Chrysler Corp. codes for the colors, what are you asking? Do you want the codes/formulas for a specific brand of paint? What brand, what line?
Rallye Green metallic is also 97 on the fender tag of a friend's A12 Runner. I think the color is the same or real darn close to the 69 Camaro green.
[Re: Beep Beep]
#1200524
03/21/12 08:41 AM
03/21/12 08:41 AM
Posts: 5,142 East Aurora (Buffalo) NY
RoadRunner
You will need to know what brand of paint first. Any reputable piant shop or body shop will be able to look up the forumula. Make sure they get the right year though as the paint formula may change from year to year with the same fender tag paint code. Most good paint shops have a coumputer that can determine the right forula and give it to them in the various type of paint (singel stage, BCCC, etc).
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: DPelletier]
#1200528
03/21/12 10:23 AM
03/21/12 10:23 AM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
I tried a couple different paints before doing my car. I don't have the number here at work but I can get it if you like. Dave ![](http://i34.piczo.com/view/3/n/2/x/u/3/o/a/4/o/z/5/img/i282364418_19009_6.jpg)
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: RoadRunner]
#1200529
03/21/12 03:48 PM
03/21/12 03:48 PM
Posts: 1,670 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
I agree with this. I went to a dealer, maybe PPG, and what they had to offer was the color coat in a medium priced quality and a clear coat that raised the overall quality to top of the line.
The 69 Plymouth Service Manual, page 23-151 says, "F8, Ivy Green Metallic, Chrysler Code AY2EF8, Ditzler Code *43786", where * means carry-over color.
If anyone is interested, here's F8, the medium green, compared to F5, the light green, in bright sun. Jusy like your bottom (maybe), this paint had never seen the light of day, until this moment, because it is the inside surface of the door, under the door panel.
[Re: kentj340]
#1200530
03/21/12 04:09 PM
03/21/12 04:09 PM
DPelletier
Actually EF8 = Dark Green Metallic (actual Dodge name for it - Plymouth calls it Ivy); EF5 = Medium Green Metallic (Plymouth Limelight) and EF-3 is Light Green Metallic (Plymouth Frost Green Met.)
I was lucky enough to find a perfect sample of paint under my front windshield rubber that was never exposed to the elements and I used that for my color match. Of course, lighting, cameras and computer monitors all play a part. For example;
the garage under flourescent lights:
![](http://i34.piczo.com/view/3/n/2/x/u/3/o/a/4/o/z/5/img/i282364386_90294_6.jpg)
1974 'Cuda
[Re: DPelletier]
#1200536
03/22/12 09:26 PM
03/22/12 09:26 PM
Posts: 749 NY
Beep Beep
NY
