Re: So anyone try the MSD atomic EFI yet? [Re: deansrr] #1200511
03/22/12 01:14 PM
03/22/12 01:14 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
As far as replacement sensors -
Most every aftermarket system I have investigated standardized on GM-type sensors, meaning the sensor resistance curves are comparable to what GM used. There are a plethora of variations in the aftermarket regarding wiring connectors, mounting threads, etc, but if you're needing a replacemnt part ASAP you'll probably be able to get something that would work, or could be rigged in temporarily, at a parts store. Looking at a part for a 1990 GM __________ is a good starting point.
And for any home-brewed JY EFI system, unless you get it all for free you better plan on spending at least $500 minimum. A new 45 PSI pump will run $80 minimum, fuel lines and fittings aren't free, you'll want new sensors ($50 easily) - it adds up quick. A junkyard ECU will be $50 minimum, too.
And there's a TON of info and upgrade parts out there for the GM TBI system, and even though TBI is frowned upon it still offers lots of benefit over a carb.
OK, sidetrack over...
Re: So anyone try the MSD atomic EFI yet? [Re: Fury Fan] #1200512
03/26/12 06:22 PM
03/26/12 06:22 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
Well went ahead and order parts today, Atomic efi, dist, coil and rotor, free 6A box, by rebate, save myself over $228. Suppose to get car back late April, can wait to install!! anyboby need a quikfuel E85 Carb!!
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
Re: So anyone try the MSD atomic EFI yet? [Re: deansrr] #1200513
03/26/12 09:37 PM
03/26/12 09:37 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Cool. I look forward to hearing about your install, and the results!
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: So anyone try the MSD atomic EFI yet? [Re: deansrr] #1200514
06/04/12 07:47 PM
06/04/12 07:47 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
sorry to dredge up such an old thread, but did you get your EFI up and running?
Re: So anyone try the MSD atomic EFI yet? [Re: Pool Fixer] #1200515
06/04/12 09:35 PM
06/04/12 09:35 PM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
UPS will be delivering mine tomorrow! I am however still WEEKS away from having the car to the point where I can try to run it.
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: So anyone try the MSD atomic EFI yet? [Re: finadk] #1200516
06/11/12 02:07 AM
06/11/12 02:07 AM
Itasca, Texas
Mad_Scientist Offline
Itasca, Texas
I installed it on my 440 a few months ago and I love it. Just answered a few questions and it started right up. There is some manual tuning that you have to do, but it is simple. Took the car on a 400 mile trip a few weeks after the install and had no problems. It was well worth the money, in my opinion. I did an in tank pump install with my kit.
69 Super Bee 440 5-speed
70 Dart Swinger 340 4-speed
69 Camaro SS 396 4-speed
66 Cutlass Convertilbe
70 Judge Ram Air III 4-speed
68 F-100 SWB
