HELP!!! 70 Body fuel gauge won't work!!! #120045
09/13/08 02:52 PM
09/13/08 02:52 PM
Anonymous OP
Anonymous OP
This thing is wearing me out .........It should be working, but it isn't.........Here's what I've done;
If I ground the wire back at the tank, it pegs the gauge...........so I know everything from the wire to the gauge is fine..........
It's a brand new sending unit with a good float.......If I have it out of the tank with the fuel gauge wire hooked up and a wire attached from the sending unit to the body for a ground, the gauge works perfect.......With the float all the way down, it shows empty, with the float about half way, it shows half full, and with the float all the way up, the gauge shows full.........
With the sending unit out and on my table and the float all the way down, it shows 82 on my resistance setting of my meter.......With the float all the way up, it shows 13.........With the float roughly in the middle of it's travel, it shows roughly 38........
Right now, I've got about a half a tank of fuel in it........If I put the sending unit in the tank, the gauge won't go above an 1/8 of a tank, even if it's full of fuel........I hook up my meter and it reads 42, so it should be working.......I've checked and double checked to make sure the sending unit is grounded properly when in the tank and it is......and yes, there is a ground wire from the engine to ground........
What am I missing???
Re: HELP!!! 70 Body fuel gauge won't work!!! #120046
09/13/08 03:33 PM
09/13/08 03:33 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Silly questions????
Any chance you have the wrong sending unit????
Or is something limiting the travel of the float arm when installed????
Step back and look at the problem,
sounds like the solution is probably staring you in the face but your not seeing it, not trying to be a smart a-- but rather help
Tim
Re: HELP!!! 70 Body fuel gauge won't work!!! [Re: TJP] #120047
09/13/08 03:48 PM
09/13/08 03:48 PM
Anonymous OP
Anonymous OP
Silly questions????
Tim
That's what I keep thinking..........It has to be right in front of me but I can't see it.......
I found a pic of the sending unit in the Year One catalog and it looks correct by the pic......I even made sure it's touching the bottom of the tank........and with the unit in the tank with a half a tank of fuel in it, my meter shows it's reading about halfway......
It's a new tank.........and the float moves easily when out of the tank.......even if I hold it sideways a little.......I even made sure that it's indexed correctly while in the tank.......
This thing is kicking my butt.........
Re: HELP!!! 70 Body fuel gauge won't work!!! #120048
09/13/08 05:57 PM
09/13/08 05:57 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Put it in and attach a good ground to it.If its not grounding good it wont work right.I run a 12 gauge wire to the body and attach the other end with a tiny hose clamp to the sender outlet tube.I dont have a lot of faith in the factory ground that they came with.Rocky
Chrysler Firepower
Re: HELP!!! 70 Body fuel gauge won't work!!! [Re: therocks] #120049
09/13/08 06:13 PM
09/13/08 06:13 PM
California, USA
blairboy3 Offline
blairboy3  Offline
California, USA
I was thinking the same thing. Doesn't matter if it's grounded to the tank, needs to be well grounded to the chassis.
1968 Plymouth Fury III 4-Door: 12.79 @ 115, 60'- 1.93 (Hey... it's a Cruise ship... what do you expect?!) Famoso Raceway, 02/08
Re: HELP!!! 70 Body fuel gauge won't work!!! [Re: blairboy3] #120050
09/13/08 06:21 PM
09/13/08 06:21 PM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
Here's vote number three for you having a bad ground when the unit is installed. Add another ground from the body of sending unit to a good ground on the car body and see if it changes anything. I had to use a supplemental jumper ground on mine to get it to work correctly.
Good luck
Re: HELP!!! 70 Body fuel gauge won't work!!! [Re: rss] #120051
09/13/08 08:12 PM
09/13/08 08:12 PM
Anonymous OP
Anonymous OP
I'll give it a shot.......All it has is a new stock grounding strap.......I used my meter and touched the black lead to the stock grounding strap and the red lead to the sender connector and the meter reads right, but maybe it's not enough of a ground???
Re: HELP!!! 70 Body fuel gauge won't work!!! #120052
09/13/08 08:45 PM
09/13/08 08:45 PM
South Texas
badchallenger Offline
Fluff Flipper
Fluff Flipper
South Texas
There is also a possibility that the float arm might be lose and if lifted up buy the gasoline it would pull the needle on the rheostat away and not making contact. This is very doubtfull though. i would guess its the ground also.
U.S. Navy Sea Bees (Retired now) U.S. Army Civil Service NDT
Re: HELP!!! 70 Body fuel gauge won't work!!! [Re: badchallenger] #120053
09/13/08 09:39 PM
09/13/08 09:39 PM
Anonymous OP
Anonymous OP
I'd thought of that too, so I took it apart and bent the needle to it hits the rheostat harder........
Re: HELP!!! 70 Body fuel gauge won't work!!! #120054
09/14/08 12:48 PM
09/14/08 12:48 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Welcome to the world of replacement fuel senders , I don't know of any that work properly ...
Wayne , what it he resistance between the sender body and ground with your ground strap in place ?
Re: HELP!!! 70 Body fuel gauge won't work!!! [Re: JohnRR] #120055
09/14/08 01:35 PM
09/14/08 01:35 PM
Anonymous OP
Anonymous OP
It reads .8 on my meter.........and that's with an additional wire that's clamped to the sending unit and bolted to the frame..........and it still doesn't work........
Re: HELP!!! 70 Body fuel gauge won't work!!! #120056
09/14/08 01:53 PM
09/14/08 01:53 PM
I would temporarily run a long jumper wire from the sending unit metal body DIRECTLY all the way up to the batt neg terminal.
Re: HELP!!! 70 Body fuel gauge won't work!!! #120057
09/14/08 02:40 PM
09/14/08 02:40 PM
SE, Pa
Hotwheel Offline
Hotwheel  Offline
SE, Pa
I have exactly the same situation with my 70 GTX. Ive done all the same trouble shooting and fixes, still will only go half way up when the tank is full. I spent many hours trying to figure out what I missed and just said the heck with it, really pisses me off though.
09 Challenger B5 Classic 78 Magnum GT Check out my Website http://home.comcast.net/~tlyerk/troy1.html
Re: HELP!!! 70 Body fuel gauge won't work!!! [Re: Hotwheel] #120058
09/14/08 02:42 PM
09/14/08 02:42 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
When I had redline rebuild my gauges they called me for the ohm measurements on my sending unit and calibrated my gauge to the sending unit.
Re: HELP!!! 70 Body fuel gauge won't work!!! [Re: RapidRobert] #120059
09/14/08 04:21 PM
09/14/08 04:21 PM
Anonymous OP
Anonymous OP
I just got back from doing that and it's still the same......
What I don't get is, with the float out of the tank, a ground wire clipped from the sending unit to the fuel sender ground strap, it works perfect........I can move it from empty, to half way, to full, and the gauge reads right...........
It's as if the sender being in gasoline is causing the problem......
Re: HELP!!! 70 Body fuel gauge won't work!!! #120060
09/14/08 06:01 PM
09/14/08 06:01 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Wayne I did a tongue in cheek back and forth with someone else recently on this EXACT SUBJECT and I asked this question which I got no reply to .
How do you know that the level you are raising it to is the actual level its going to inside the tank when its full of fuel ?
Re: HELP!!! 70 Body fuel gauge won't work!!! [Re: JohnRR] #120061
09/14/08 06:42 PM
09/14/08 06:42 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
  • In other words what reading are you getting?
  • Remember your tank is only 12" tall or so and long and wide.
  • This means that if the car is jacked up in the rear the fuel will move to one side and the level in the tank will be off.
  • Also you may have to bend your float arm so when the car is level and half full of gas the guage will read the same.
  • Last edited by HealthServices; 09/14/08 06:47 PM.
    Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
    Re: HELP!!! 70 Body fuel gauge won't work!!! [Re: HealthServices] #120062
    09/14/08 06:56 PM
    09/14/08 06:56 PM
    Anonymous OP
    Anonymous OP
    All I do know is that with my ohm meter, I can check the reading at the sender while in the tank and it reads roughly halfway.......about 42 on my meter..........
  • I have the car on my drive on, 4 post lift, so the car is sitting just as it would be on the ground......
    I've also bent the float arm so it would make the fuel gauge read even higher (which I've done in the past on different cars and it's moved the needle to where I've wanted).........
    It kills me that with the sender out of the car and hooked up, I can move it through it's travel, and the gauge works correctly!!! That keeps me thinking it's a ground problem, but I think I've eliminated that by running a heavy gauge wire from the sender to the battery!!! Where's the head bangin' the wall emoticon???
    Re: HELP!!! 70 Body fuel gauge won't work!!! #120063
    09/14/08 08:33 PM
    09/14/08 08:33 PM
    U.S.S.A.
    JohnRR Offline
    JohnRR  Offline
    U.S.S.A.
    It might be partly a ground problem as .8 ohms isn't really 0.
    any idea what the original sender read when it was at half a tank ?
    how do you know what you have in the tank is actually half a tank ?
    I'm not sure what my Dart has for a sender , my tank is painted on the outside , but when I fill it , the fill nozzle shuts off and spits fuel down the side of the car , it only reads 3/4.
    I have a new sender , 3/8 line , and I have a new sender for my Bee also , I am NOT looking forward to replacing the senders .
    Re: HELP!!! 70 Body fuel gauge won't work!!! [Re: JohnRR] #120064
    09/14/08 09:23 PM
    09/14/08 09:23 PM
    Anonymous OP
    Anonymous OP
    What's odd is, I can use that exact same ground wire, attached to the sender with it out of the car, and it works!!!
    The guy brought this car to me like this.......
    When I'd found that the float had a hole in it and was full of fuel, I'd installed a new float and filled it up with fuel.......On the way home the gauge slowly worked it's way up to the half way mark........so I figured I'd drain some fuel, bend the float lever to make the gauge read higher, and then reassemble........I drained 6 gallons out from full and that's just below the bottom of where the sender goes in.......so I know I'm 6 gallons from full.........
    I've been down this road before, a bunch of times.....and have never had one get the best of me..........
