So anyone try the MSD atomic EFI yet? #1200491
03/20/12 11:07 PM
03/20/12 11:07 PM
USA
CrAlt Offline OP
CrAlt  Offline OP
USA
It looks like a well thought out system but I have doubts about replacement sensor availability and pricing?
Has anyone tried it on anything yet?
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
Re: So anyone try the MSD atomic EFI yet? [Re: CrAlt] #1200492
03/20/12 11:28 PM
03/20/12 11:28 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
I would love to give it a try on my boosted car to see just how well it would "self learn". Too bad it's $2300
Re: So anyone try the MSD atomic EFI yet? [Re: CrAlt] #1200493
03/21/12 03:35 AM
03/21/12 03:35 AM
Davis, California, USA
MrBelvedere2 Offline
I am waiting to see if anyone has tried it out too as I am very interested in the system. Definetly seems very well thought out. I saw in one of the new issues of hot rod they had an article about it in the new products section, and they said to keep an eye out as they are going to do a test on one pretty soon. In usual hot rod fashion, it should be a good write up of what to expect.
1965 Plymouth Belvedere II hardtop
Re: So anyone try the MSD atomic EFI yet? [Re: MrBelvedere2] #1200494
03/21/12 03:39 AM
03/21/12 03:39 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I read about some EFI system recently that looked exactly like a carburetor. The fuel boals were only covers, there to hide the EFI components. Is this the same setup?
Re: So anyone try the MSD atomic EFI yet? [Re: Kern Dog] #1200495
03/21/12 04:02 AM
03/21/12 04:02 AM
Yeah pretty much is what you are describing. Everything is hidden in the throttle body, TPS,MAP,injectors, etc. What I like is it uses pulse modulation to regulate how much fuel it needs, so you don't need to modify your fuel tank or run a return line.
www.atomicefi.com
Re: So anyone try the MSD atomic EFI yet? [Re: MrBelvedere2] #1200496
03/21/12 04:04 AM
03/21/12 04:04 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I checked that link. This is not the same as what I read elsewhere. the setup that I recall used what looked like Barry Grant fuel bowls.
Similar to my Speed Demon carburetor.
Re: So anyone try the MSD atomic EFI yet? [Re: CrAlt] #1200497
03/21/12 11:50 AM
03/21/12 11:50 AM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
There was another thread on this here at Moparts a few weeks ago...and I shared your concern with parts availability and pricing.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: So anyone try the MSD atomic EFI yet? [Re: Kern Dog] #1200498
03/21/12 11:57 AM
03/21/12 11:57 AM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
I will be putting one on my 73 RR 340 as soon as my body guy is done with it. I want to run E85, which is common around my area, but not across the country. I will be adding their dist and a 6AL box, with this setup i will be able to reprogram it to run reg gas or e85 with just a hand control switch, I talked to MSD quite a long time at SEMA and sounds like this is the perfect setup for me.
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
Re: So anyone try the MSD atomic EFI yet? [Re: deansrr] #1200499
03/21/12 12:20 PM
03/21/12 12:20 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
That is one of the draw backs of the EZ-efi. No E85 compatability...I was hoping to see that as a software upgrade, but so far nada...
Re: So anyone try the MSD atomic EFI yet? [Re: Kern Dog] #1200500
03/21/12 02:49 PM
03/21/12 02:49 PM
Finland
CarelianCuda Offline
Finland
How about Powerjection III? http://www.professional-products.com/EFI_3.php
I have the returnless 70029, but not yet installed
1970PlymouthCuda383
1970AMCHornet2D232
2003TruckmastersOkenosDurangoSlt+
2008DodgeChallengerSRT8
Re: So anyone try the MSD atomic EFI yet? [Re: Dragula] #1200501
03/21/12 03:53 PM
03/21/12 03:53 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
That was my plan, but at SEMA FAST guy told me they have put it on the back burner for now.
Re: So anyone try the MSD atomic EFI yet? [Re: CrAlt] #1200502
03/21/12 06:59 PM
03/21/12 06:59 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Wonder how long till the knockoffs start washing up on shore.
I cannot afford one at $2300 but if there were a half-priced alternative it might be hard to resist.
Re: So anyone try the MSD atomic EFI yet? [Re: Exit1965] #1200503
03/21/12 07:20 PM
03/21/12 07:20 PM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
You can DIY with GM junk on the cheap... it's just a lot more work to set up
http://grimers.com/vehicles/68wagon/efi/moparefi.php
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: So anyone try the MSD atomic EFI yet? [Re: deansrr] #1200504
03/21/12 09:38 PM
03/21/12 09:38 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
If I did this, I would love to have an E85 option, though it's not essential in my application.
Check out this previous comment...
At Summit, the 70026 complete kit is $1683.95. (Not sure what the system differences are between 70026 and 70029)
Summit
DynoDave
Member # 12304
Re: So anyone try the MSD atomic EFI yet? [Re: Secret Chimp] #1200505
03/21/12 09:57 PM
03/21/12 09:57 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
Maybe all the GM parts worked on his eyes, check out the fuel filter...Chevy speed secret maybe?
It takes gasoline to interest me.
Re: So anyone try the MSD atomic EFI yet? [Re: VL21] #1200506
03/21/12 10:49 PM
03/21/12 10:49 PM
Eugene, Oregon
Eugene, Oregon
Heh, it's very poorly documented and probably pretty old. I bet a MegaSquirt II could control all of those components easily with a lot of community help for the ECU. A MS+junkyard part EFI setup could probably be done for several hundred dollars easily. Heck, forget hacking on crappy GM TBI stuff, get a Magnum intake manifold and its associated top-end hardware and you're already halfway there for a small block.
Re: So anyone try the MSD atomic EFI yet? [Re: CrAlt] #1200507
03/21/12 10:54 PM
03/21/12 10:54 PM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
Maybe a little off topic but not totally. With the expense of the EFI (which I am exploring also) how much will the system add to the value of the vehicle? If you already have a $20,000 ride and add either the EZ EFI or the MSD will the car be worth $2,000 more with the EFI?
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: So anyone try the MSD atomic EFI yet? [Re: Kern Dog] #1200508
03/21/12 11:24 PM
03/21/12 11:24 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
Not sure, but maybe you are talking about Retrotek efi? that was out a few years ago. Horsepower TV put one on a 66 or 67 charger and one of the magazines put it on a car. All I remember is that the magazine guys took it off because they had some issue with it. I think Retrotek is the same as the professional products. While Atomic and EZ efi look sort of like a carb, that Retrotek looks exactly like a carb.
Re: So anyone try the MSD atomic EFI yet? [Re: deansrr] #1200509
03/22/12 12:13 AM
03/22/12 12:13 AM
USA
CrAlt Offline OP
CrAlt  Offline OP
USA
I'll be looking forward to your review. I just got a thing from JEGS that they are giving away a free 6A box when you order the kit.. FYI.
Re: So anyone try the MSD atomic EFI yet? [Re: CrAlt] #1200510
03/22/12 11:44 AM
03/22/12 11:44 AM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
I talked to MSD yesterday and will need Dist 8534, rotor 84211, 6A box (and yes send in rebate for it) and the Atomic kit2910, I already have fuel pump and lines done already. My warehouse is having a sell March 26-28, so I will be curiuos how much I will save. My car is suppose to be back the end of April so it won't be till May till I can put it on.
