Re: disc brake swap
[Re: dart683341]
#1200473
03/20/12 09:31 PM
03/20/12 09:31 PM
RapidRobert
Grab the prop valve. Other than that nothing other than the obvious stuff like the horse shoe brackets and their bolts, dust shields. I would get new brake hoses and the correct brass washers (4) at your dealer ($$$) that go on either side of the 2 banjo hose fittings. If you do get new rebuilt calipers (a good idea) (23xx ea) ask for '76 dart calipers as they have a significantly larger bore (2.75 vs 2.60") than '73-75 A calipers for more front bias.
Re: disc brake swap
[Re: Cab_Burge]
#1200476
03/21/12 09:36 AM
03/21/12 09:36 AM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
Grab the master also.Its good for a core.That and you will have the rod with it.Usually dosent cost anymore when you are getting all the other stuff.Rocky
Chrysler Firepower
