Windage tray spacing on a 360 #1200334
03/20/12 05:18 PM
03/20/12 05:18 PM
Parsons (SouthEast) Kansas
funkyjbp Offline OP
mopar addict
funkyjbp  Offline OP
mopar addict
Everyone, I have slotted the holes on my 318-340 tray to fit on my 360 main bolts. Anyone know the correct spacing down? I have mocked it up using studs and washers but I had to use 3/8s of an inch to get it to clear the rods. I also bent it out a bit for clearance and now it's hitting on oilpan rail. Also, how much clearance is needed between tray and rod bolts? Just curious if anyone has done this before. Thanks, JP in the land Oz.
71 SWB, 413 77 SWB, 318 92 SWB, 5.2 magnum 79 Macho Short bed, 318 03 stratus coupe R/T too many others not on the road!
Re: Windage tray spacing on a 360 [Re: funkyjbp] #1200335
03/20/12 08:43 PM
03/20/12 08:43 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I pulled a mopar windage tray off my 318 and bolted it straight on my stock stroke 360 without any clearance problems at all. I did pry the drain slots open a little further as the mopar tray has been said to hold oil too long returning to the pan when pushed hard. Is your 360 a stroker?
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Windage tray spacing on a 360 [Re: GO_Fish] #1200336
03/20/12 09:08 PM
03/20/12 09:08 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Back in the day, there was a specific windage tray for the 360. MP's windage tray is a universal fit unit, fits the 360 as well as the other LA's.
I have always had the windage tray want to ride on the oil pan rail, just wedge it out of the way, put the pan on without the timing chain cover and you can eyeball the fitment.
Don't be the exception.
Re: Windage tray spacing on a 360 [Re: GO_Fish] #1200337
03/21/12 12:02 PM
03/21/12 12:02 PM
funkyjbp Offline OP
mopar addict
funkyjbp  Offline OP
mopar addict
I have a 318-340 tray & am using on a stock stroke 360. The mopar performance trays come with slotted holes & washers to use under main bolts. I would like to get the washer thickness so I can space my tray accordingly. I got burned on ebay by buying a "360" tray as advertised. So I am trying to make it work. Thanks, JP in the land of Oz.
